I am "learning" LR slowly. I like using it and sometimes just load a set of photos to "experiment" with for the express purpose of teaching myself in a hands on learning way.
When I have an image loaded into LR, and I want to "Export" it using another file name, is there a way to force the exported file to retain the "original" file name in metadata?
File Img90009.jpg > Hot_Rods_001.jpg - keeping the img90009.jpg file name in metadata so that 3 or 4 months from now when I want to find the "original" file all I need to do is look at the metadata and I'll know where and which file I want to look for!
Is this possible?
Is there a better way?
I have noticed that the EXIF data does HAVE a place for the original file name, but the original file name is NOT recorded in the data. It there something I am missing here, a setting, check box, or something that WILL record the original filename (as per the camera's file naming sequence) into the EXIF file? That would also be a good way to do what I want and probably easier as I try not to ever strip the EXIF data from files even when re-sizing them in other programs.
Hillbille
