Im looking to try my hand at landscape photography and i just wanted to know when do you know when to use a CP filter or a ND filter?
thanks
Steve
SteveSanchezPhotography Member 120 posts Likes: 11 Joined Oct 2011 More info | Nov 20, 2013 18:21 | #1 Im looking to try my hand at landscape photography and i just wanted to know when do you know when to use a CP filter or a ND filter?
Phrasikleia Goldmember 1,828 posts Likes: 14 Joined May 2008 Location: Based in California and Slovenia More info | Nov 20, 2013 21:36 | #2 The primary use of a circular polarizer is to control reflections, whether they are from water, foliage, or particles in the sky. The primary use of an ND filter is to reduce the amount of light reaching the camera's sensor, which can enable slower shutter speeds to create motion blur (in waterfalls, for example). Some ND Filters are graduated (that is, their effects fade from one end of the filter to the other); these filters can help to balance scenes that have a lot of light in only one area (for example, a bright sky versus darker land). These latter types of filters (called "GNDs" for short) are going out of fashion in the digital era because digital editing techniques have largely rendered them obsolete. Photography by Erin Babnik
It isn't always obvious when a CP is going to be useful. You'll hear all sorts of nonsense about using them, but really the only way to know for sure is to look though one and rotate it to see if it helps the scene. Remember you don't have to use it at maximum polarization. Edward Jenner
Nov 21, 2013 08:56 | #4 Ok thanks guys
Careful if you use one on a wide angle lens. If you get a lot of sky in your photo, the polarization will be uneven, and that will mean an uneven sky, that is, dark blue in one section, lighter blue in another.
Nov 23, 2013 06:35 | #6 Patrick thanks for the tip
| Latest registered member is Marcsaa 507 guests, 152 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
