Thread started 01 Feb 2006 (Wednesday) 12:30
ACR Settings???
bryno74
Feb 01, 2006 12:30 |  #1
I would like to know what some of you guys are using as default start settings with the 20D.... Thanks
EOS-1D Mark III - 70-200 2.8 - 300mm 2.8L IS - 580EX II
http:// …
tim
Light Bringer
Feb 01, 2006 17:36 |  #2
My default is "don't mess with my photo". That's exposure 0, shadows 5, contrast 25, brightness 50, saturation 0.
Robert_Lay
Feb 01, 2006 22:08 |  #3
I favor the defaults that were coded in for my camera (but that's a G5 and you are only concerned about the 20D).
However, philosophically, I would think the same approach would apply to all cameras. The reason I favor the defaults (what you get when you do "Reset Camera RAW Defaults") is that this seems to come very close to the image that will come out of the camera when set to JPG instead of RAW. In other words, I could believe that the ACR designers tried their best to hack the Canon algorithms that create the JPG format output.
What I have said here only applies to ACR 2.4, because in 3.3 there are optional Auto settings on each control that can make for a completely different image when turned on. In other words, the "Camera RAW Defaults" for a given camera are apparently assuming that you turn off those Auto check boxes in version 3.3.
Bob
Quality of Light (external link), Photo Tool ver 2.0 (external link)
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
bryno74
Feb 01, 2006 23:26 as a reply to  @ Robert_Lay's post |  #4
Thanks guys for the info....
http:// …
jfrancho
Feb 02, 2006 08:31 |  #5
I'm with tim, same settings. For WB, I use, "As shot."
BoySpot
Joined Feb 2004
Feb 04, 2006 18:49 |  #6
On the WB, I often experiment with the dropper tool to find a better setting than the 10D comes up with. It can be signficantly different.
tim
Light Bringer
Feb 04, 2006 22:28 |  #7
I've done quite a lot with the ACR white ballance tool for yesterday, since the light changed often and I usually don't think to change it when i'm so busy. I have enough things to worry about on a wedding day.
3,298 views & 0 likes for this thread, 5 members have posted to it.
ACR Settings???
2090 guests, 101 members online
