Thread started 21 Nov 2013 (Thursday) 19:40
Can PW TT5 trigger AB?
sf1
Nov 21, 2013 19:40 |  #1
I have a mini TT1 on camera and want to trigger my Alien Bee with the TT5, but it doesn't want to fire. Connecting using a mono cable to the p2 of the TT5 and the sync on the AB.
Should it work this way?
Canon 5DII, Canon 1D Mark II N
Canon 24-70 mm f/2.8 L, Canon 85 mm f/1.8, Canon 70 -200 mm f/2.8 IS L, Canon 400 mm f/5.6 L, Canon 50 mm f/1.4, Manfrotto 055XPROB & 488 RC2
Canon Speedlites 580 EX, 430 EX II & 3 PW II, iMac I7, MacBook Pro, Aperture 3, CS5
Strobo
Joined Sep 2013
Nov 21, 2013 22:44 |  #2
sf1 wrote in post #16470606 (external link)
Short answer is yes, it should work. When you use the P2 port you are not using the Control TL channels, so you need to make sure the TT1 transmit and TT5 receive standard channels match.
dmward
Gallery: 29 photos
Nov 21, 2013 23:15 |  #3
Invest the money and get an AC9. It will give you the ability to fire and remotely control the power on your AB mono. Well worth the investment.
SMP_Homer
Gallery: 29 photos
Nov 22, 2013 14:42 |  #4
dmward wrote in post #16471043 (external link)
Don't stop there... get more lights, and an AC3....
EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
Sig35A, Sig50A, Sig85A, Sig14-24A, Sig24-105A, Sig70-200S, Sig150-600C
100-400L, 100L, 100/2, 300 2.8L, 1.4x II / 2x II
600EX-II X3, 430EX-III X3
umphotography
grabbing their Johnson
Gallery: 21 photos
Nov 22, 2013 15:25 as a reply to  @ SMP_Homer's post |  #5
Make sure your on the same channels. You should be able to fire any AB with that set up.
Mike
www.umphotography.com (external link)
Facebook (external link)
LEoVaMPiRe
Feb 28, 2014 21:09 |  #6
I have the same problem! I just received AB1600 and I tried to hook it via 1/8 mono cable to the TT5. However, it simply didn't fire. Do you have a specific settings in order for this setup to work? Please share with us. Thank you in advance.
Alaa Marzouk
: 5D MK-III / 6D / Canon 135L / / Σ 50mm 1.4 ART / Σ 35mm 1.4 ART / Canon 17-40mm f/4L / Canon 70-200 f/2.8L IS II /
Facebook https://www.facebook.c​om/alaa.marzouk (external link)https://www.facebook.c​om …otography/20735​6589307848 (external link)
Strobo
Joined Sep 2013
Mar 02, 2014 15:49 |  #7
Yes, it should. When you press the test button on the transmitter do you see the red light flash on the TT5? Does the flash fire when you press the test button on the strobe TT5?
1,910 views & 0 likes for this thread, 6 members have posted to it.
642 guests, 122 members online
