Thread started 22 Nov 2013 (Friday) 15:43
Canon 60D Service Manual
Chopper ­ Al
Nov 22, 2013 15:43 |  #1
I've been searching trying to find a Canon 60D service manual, but with no luck.
Does anyone know where I might download or buy one?
Thanks in advance...
Al
MakisM1
Gallery: 50 photos
Joined Dec 2011
Nov 22, 2013 16:34 |  #2
http://gdlp01.c-wss.com …19/03/eos60d-im3-c-en.pdf (external link)
Let it download and save the pdf
Gerry
sbgagne
Joined Apr 2011
Nov 22, 2013 17:19 |  #3
MakisM1 wrote in post #16472778 (external link)
That appears to be the instruction/user's manual. He is looking for the service manual. I have been looking as well and have not found it as of yet.
Chopper ­ Al
Nov 22, 2013 18:20 |  #4
Well, if I do find one, I will certainly post it here.
xarqi
Nov 22, 2013 19:54 |  #5
I will not be pushed, filed, stamped, indexed, briefed, debriefed or numbered.
You should get together with "number six", a fellow POTNer.
unistudent1962
Nov 23, 2013 02:05 |  #6
https://photography-on-the.net …/showthread.php​?t=1216590
This thread has links to Service Manuals on a server called FileFactory.
No idea how you download them though
Canon 70D w/Grip l Canon 60D w/Grip l EF 100-400 F4.5-5.6L IS l EF 70-200 f4L IS l EF-S 15-85 f3.5-5.6 IS USM l EF 100mm f2.8 USM Macro l EF-S 18-55mm f/3.5-5.6 IS STM l EF 50 f1.8 II l EF-S 10-22 f3.5-4.5 USM l 430 EX II Flash l Manfrotto 055XPROB + 498RC2 Tripod l Benro MP-96 M8 Monopod l Lowepro Vertex 200 AW Backpack l Lowepro Pro Runner 300 AW Backpack l PS CS5 Extended l Lightroom 4.3
John ­ from ­ PA
Joined May 2003
Nov 23, 2013 07:11 |  #7
unistudent1962 wrote in post #16473700 (external link)
I've gone through the steps at FileFactory for the freebie download and got a decent sized file in about 2 minutes. If you pay the file can come across sooner. However, and what concerned me, was the file was a "exe" file. I suppose it could be a self-extracting zip file but I chose not to find out if it was something else.
If you do the download, then I would suggest you run an antivirus scan on it prior to extracting the contents.
pillainp
Nov 23, 2013 11:37 |  #8
John from PA wrote in post #16473957 (external link)
When you download from places like that, they will give you the choice to download using their downloader (enabled by default), which is basically usually just an adware utility.
If you look around on the page, you can find the button to disable that option and download the file directly.
11,633 views & 0 likes for this thread, 7 members have posted to it.
921 guests, 108 members online
