I can't decide between the 2. I already have the 24-105 and a 20mm for a bit more stretch. Would I gain enough to justify the expense by going with a 17-40?
eddieb1 Senior Member 986 posts Likes: 227 Joined Apr 2013 Location: Oregon More info | Nov 22, 2013 19:53 | #1 I can't decide between the 2. I already have the 24-105 and a 20mm for a bit more stretch. Would I gain enough to justify the expense by going with a 17-40?
howiewu Senior Member 629 posts Likes: 21 Joined Feb 2011 More info | Nov 22, 2013 20:07 | #2 Yes. 5DII, 70D
Jerobean Senior Member 785 posts Likes: 1 Joined Mar 2008 More info | i want to try and help but your question (is there a question?) isn't clearly stated. _______________
Nov 22, 2013 20:14 | #4 Jerobean wrote in post #16473206 i want to try and help but your question (is there a question?) isn't clearly stated. so, maybe. I don't know how better to state the question. Is the 17-40 so much better that it would justify buying, eventhough I already have the 24-105?
ickmcdon Senior Member 323 posts Joined Apr 2012 Location: North Dakota More info | Nov 22, 2013 20:37 | #5 Yes, I have both, and there are definitely uses for both.
jjaenagle Goldmember 1,506 posts Joined Sep 2008 Location: richmond, va More info | Nov 22, 2013 20:43 | #6 Permanent bani dont think so... idk, seems redundant, but ive never had both. i would say a wide prime.
howiewu Senior Member 629 posts Likes: 21 Joined Feb 2011 More info | Nov 22, 2013 21:34 | #7 eddieb1 wrote in post #16473211 I don't know how better to state the question. Is the 17-40 so much better that it would justify buying, eventhough I already have the 24-105? Then your title should be "and" not "or". The answer is still yes. 5DII, 70D
ScottM Goldmember More info | Nov 23, 2013 08:38 | #8 eddieb1 wrote in post #16473211 I don't know how better to state the question. Is the 17-40 so much better that it would justify buying, even though I already have the 24-105? It depends on what subjects you shoot, your camera model, and whether you like to shoot ultra-wide. Providing those facts will better state the question.
Sirrith Cream of the Crop More info | Nov 23, 2013 19:56 | #9 I have both, and yes, the 17-40 is completely different. 17mm is much wider than 24. -Tom
dscri001 Senior Member More info | Nov 24, 2013 02:01 | #10 I try to choose lenses based on their specific function, fast, macro, telephoto, ultra wide, etc. Overlapping focal lengths is not always bad. The 17-40 is well worth it. -Tyler I II
unistudent1962 Member 166 posts Likes: 1 Joined Sep 2010 Location: Brisbane QLD Australia More info | I have neither, but have the crop equivalents (almost) in the 10-22 and 15-85. In my experience some overlap in focal lengths is a good thing. Canon 70D w/Grip l Canon 60D w/Grip l EF 100-400 F4.5-5.6L IS l EF 70-200 f4L IS l EF-S 15-85 f3.5-5.6 IS USM l EF 100mm f2.8 USM Macro l EF-S 18-55mm f/3.5-5.6 IS STM l EF 50 f1.8 II l EF-S 10-22 f3.5-4.5 USM l 430 EX II Flash l Manfrotto 055XPROB + 498RC2 Tripod l Benro MP-96 M8 Monopod l Lowepro Vertex 200 AW Backpack l Lowepro Pro Runner 300 AW Backpack l PS CS5 Extended l Lightroom 4.3
xhack Goldmember 1,283 posts Likes: 2 Joined Jul 2007 Location: Edinburgh, Lothian More info | Nov 24, 2013 03:36 | #12 I have generous overlap in my three zooms : 17-40, 24-105 and 70-200. Three quite different lenses, each with a useful purpose. Quite often, I take both shorter ones out together, each paired to a 5D - a useful combination. Rarely use either on my x1.6 crop body, although they do work on the x1.3 crop of the 1D. ~ Wallace
ScottM Goldmember More info | Nov 24, 2013 06:46 | #13 xhack wrote in post #16475834 I have generous overlap in my three zooms : 17-40, 24-105 and 70-200. Three quite different lenses, each with a useful purpose. I have the same zoom lenses, along with a 100-400L. I never understood why some people here try to avoid focal range overlap between zooms. Overlap is quite useful, as it can mean fewer lens swaps, or even being able to leave a lens at home based on what you will be shooting. It gives your kit more flexibility.
macaron95 Member 162 posts Joined Nov 2012 More info | Nov 24, 2013 07:06 | #14 i used to own the 24-70 as my walkaround lens My 500px
jimewall Goldmember 1,871 posts Likes: 11 Joined May 2008 Location: Cleveland, Ohio More info | To the OP. You didn't tell us the body you are using, what you typically shoot, what you feel is limiting you with the 24-105L. How are we going to give a good informed answer to help you without (at least) these pieces of information? Thanks for Reading & Good Luck - Jim
| Latest registered member is griggt 665 guests, 121 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
