FORUMS Photography Talk by Genre Critique Corner
Thread started 23 Nov 2013 (Saturday) 00:15
My neighbor pond
skycolt
Joined Apr 2012
Nov 23, 2013 00:15 |  #1
1D IV | converted 1000D | ever changing lenses
PhotosGuy
Moderator
Joined Feb 2004
Nov 23, 2013 09:23 |  #2
#1 looks pretty dull. Some side light would have been nice. I like #2, but wish they weren't so centered top to bottom.
skycolt
Joined Apr 2012
Nov 23, 2013 10:00 |  #3
Thanks for the comment!
I think I have some problem with my screen. How do you normally calibrate it and do you use a tool for that?
Jemhead
Joined Apr 2011
Nov 23, 2013 12:08 |  #4
You'll want a decent calibration tool:
http://www.amazon.com …%2Ck%3Aspyder+c​alibration (external link)
http://www.amazon.com …rczh9_b/?tag=wi​ndowdjn-20 (external link)
and this guy has a great page for helping to use them:
http://www.damiensymon​ds.com.au/calibration.​html (external link)
5D III / Canon 50mm 1.4 / Canon 50mm 1.8 / 17-40L / 135L / 85L 1.2 II / 70-200L 2.8 IS
flickr (external link)Օ
Titus213
Nov 23, 2013 13:08 |  #5
Your first image is really quite dark.
The second image, two hooded mergansers, is too centered vertically as mentioned. It might make two separate shots, male, female.
Calibration? Use a calibration device. I use the Spyder. The latest units allow you to set the monitor brightness which can solve a host of issues.
I recently ran across an article on how to calibrate using Photoshop. I've not read it in detail and don't need it but it's here - http://www.slrlounge.c​om …libration-using-photoshop (external link). It appears to recommend knowing, understanding, and using the histogram, all good ideas. I'm just not sure of the logic of using a $300~$400 dollar software package as a substitute for a $150 calibration tool.
You can also use the test strips found on many sites like DPReview.com for monitor brightness/contrast.
Dave
Perspiring photographer.
Fitness ­ Freak
Joined Nov 2011
Nov 23, 2013 22:29 |  #6
I also use the Spyder and it can make a HUGE difference. Prior to having my monitor calibrated, I edited all my pictures and they looked great..until I got one in particular printed. It was so dark that the picture was usless; after calibrating my monitor, I discovered that the "brightness" on my monitor was apparently set to off the charts in factory. I'd definitely invest in a good calibration software.
FYI: "Fitness Freak" is also known as "Amber" outside of POTN.
http://fineartamerica.​com/profiles/1-amber-kresge.html (external link)
saea501
... spilled over a little on the panties
Gallery: 42 photos
Nov 24, 2013 07:00 |  #7
Fitness Freak wrote in post #16475531 (external link)
This is exactly where I was too. Spyder does a great job.
Remember what the DorMouse said.....feed your head.
Bob
https://www.flickr.com …282@N06/with/38​203470844/ (external link)
skycolt
Joined Apr 2012
Nov 24, 2013 12:51 |  #8
Thanks all of you! Got a spyder and will make the basis right first.
1,017 views & 0 likes for this thread
My neighbor pond
Latest registered member is Smoky Moments
1459 guests, 286 members online
