Thread started 27 Nov 2013 (Wednesday) 20:07
Help....How to replace BG in batch of photos...
jra
Nov 27, 2013 20:07 |  #1
This past weekend I shot a basketball league with 26 teams. Unfortunately, shooting in the gym was not an option as games were going on all day so I was requested to shoot on a Chroma key backdrop and then paste players into a photo of the gym taken at a different time. The photos have already been masked using the color selector now I just need to add the different BG.....which I will probably do either tomorrow or Friday. That said, is there a way to create an action that would simply add the same photo BG to every image? That would make it much easier and faster than opening up every PSD file, adding the BG and saving. I'm quite familiar with creating actions, I've just never made one that includes the use of a one image with another image.
lecherro
Nov 27, 2013 23:41 |  #2
You should be able to add in your action the commands for "open file" "Copy Layer" "Paste layer" and so on... To me personally it seems easier to do it manually tho. I think you would spend more time getting the Action to play and act correctly than you would just doing it.
First step........ Take the lens cap off.
cdifoto
Don't get pissy with me
Nov 27, 2013 23:44 |  #3
I'm not sure an action will work well on images with that level of individuality. If someone proves me wrong I'd be interested in seeing how.
D ­ Thompson
Nov 28, 2013 02:50 as a reply to  @ cdifoto's post |  #4
Give this a try. All images should be the exact same size. Make sure that all the players are cut out and saved as an un-flattened psd (only layer should show as “layer 0”). I would highly suggest copying all files including the new background to another folder for the process just in case.
To create the action: Go to the copied folder and open one of the images in PS. Make sure the Layer 0 is selected. Create New Action. Click File/Place, choose the new background image, click Place, and then enter to commit. Drag the new background image layer to the bottom of the layer stack. Click Layer/Flatten. Stop Action.
To apply to all other images: In Bridge, go to copied folder (you should see the one image with the new bg). Select all other player files. Go to Tools/Photoshop/Batch. In the dialog box choose the action you created, Source = Bridge, Destination = Save and Close, Click OK.
I ran this on some test files and it seemed to work. Hope this helps.
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
René ­ Damkot
Nov 29, 2013 06:00 |  #5
Should work. Similar:
Open the "background" image, then open the first of the "team" images.
Start recording, click BG images, select all, copy, select "team", paste.
Move "background" layer to back ((Shift)Cmd[).
Stop recording.
Close (modified) "team" image without saving.
Leave BG image open, go to bridge, select all "team" images, invoke action via Image processor.
Similar to this watermarking action:
https://photography-on-the.net …php?p=2179136#p​ost2179136
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
kirkt
Nov 29, 2013 11:16 |  #6
You can also try using data driven graphics:
https://photography-on-the.net …/showthread.php​?p=8174357
This approach assumes that each of your chroma-keyed "team" files has an alpha channel in it, ready for compositing on the back ground. Make sure you defocus your background or shoot it at the same focal length and aperture as you shot your team images so the composite looks correct.
kirk
Kirk
Car2n
Nov 29, 2013 11:38 |  #7
Download a trial of FxHome Photokey6. That would give you 30 days of chroma key fun.
Canon 1D3 / 70-200mm f/2.8L IS / 17-40mm 4.0L / 50mm 1.4 / 580EXII / Manfrotto 055XPROB/488RC2 / PixmaPro 9000ii / StylusPro 3800
1,824 views & 0 likes for this thread, 7 members have posted to it.
1315 guests, 135 members online
