Hello,
I was able to open raw files from my T4i, but I just took some pictures with my T5i and they won't open. Any ideas? I thought the raw files would be the same as the T4i.
Thank you!!
DavidSR Goldmember 1,308 posts Joined May 2008 Location: Rowlett, TX More info | Nov 30, 2013 21:03 | #1 Hello, T4i, 18-55mm IS, 55-250mm IS, 50mm 1.8, 3 Vivitar 285HV's and a set of Cactus V5 Triggers!!
DThompson Goldmember 4,062 posts Likes: 422 Joined Feb 2008 Location: Georgetown, Ky More info | Nov 30, 2013 22:24 | #2 You need to update ACR to at least 7.4 when support for the T5i was added. Dennis
tonylong ...winded More info | Nov 30, 2013 23:56 | #3 What software are you using? Tony
tonylong ...winded More info | Nov 30, 2013 23:57 | #4 So you know, Canon (as well as other outfits) change the Raw format a bit for each new model, and older software can't "read" the changes! Tony
DThompson Goldmember 4,062 posts Likes: 422 Joined Feb 2008 Location: Georgetown, Ky More info | Dec 01, 2013 00:03 | #5 tonylong wrote in post #16491843 What software are you using? Title shows PS CS6. Dennis
tonylong ...winded More info | Dec 01, 2013 00:18 | #6 Ah, OK, I missed that! Tony
| Latest registered member is semonsters 1600 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
