Thread started 02 Dec 2013 (Monday) 23:43
Canon EF-S 15-85 vs EF 24-105L
TDIDog
Joined Oct 2013
Dec 02, 2013 23:43 |  #1
I am looking at getting a good all around zoom. Any thoughts which would be a better choice? I am leaning toward the 24-105, but not sure about issues. I am using a 7D. Already have a 10-22, 40, 50 1.4, 100L macro,& 70-200L 2.8 lenses.
Thanks, all input appreciated.
BrickR
Joined Mar 2011
Dec 03, 2013 00:02 |  #2
15-85 hands down. 24mm isn't wide as an all around on a crop sensor. You gain a LOT on the wide end with the 15-85.
My junk
The grass isn't greener on the other side, it's green where you water it.
mwsilver
Gallery: 54 photos
Joined Oct 2011
Dec 03, 2013 00:10 |  #3
BrickR wrote in post #16497233 (external link)
I would generally agree, but the OP has that covered with the 10-22. I use my 15-85 as my general walk around lens, but If I had a 10-22, I might have opted for the 24-105 instead. The 15-85 is a great lens with 4 stops of IS, the 24-105 only has 3. However, the build of the 24-105 is better, the reach is a bit longer and the IQ is somewhat better. It's really a toss up. They will both do the job.
Mark
Nikon Z fc, Nikkor Z 16-50mm, Nikkor Z 40mm f/2, Nikkor Z 28mm f/2.8 (SE), Nikkor Z DX 18-140mm, Voigtlander 35mm f/1.2, Voigtlander 23mm f/1.2, DXO PhotoLab 5 Elite, DXO FilmPack 6 Elite, DXO ViewPoint 3
xarqi
Dec 03, 2013 00:18 |  #4
What Mark said. :)
TDIDog
Joined Oct 2013
Dec 03, 2013 00:23 as a reply to  @ xarqi's post |  #5
The weather sealing is a plus for me, as we get a lot of rain here, and it would be nice to not have to worry about that. Otherwise it's a tough choice!!!
1Tanker
Dec 03, 2013 00:45 as a reply to  @ TDIDog's post |  #6
I'd say the 15-85 as well. Although the OP already has a 10-22, they want a "general walkaround lens". As such, the 15-85 is very hard to beat. I have both the 10-22 and 15-85, and the 15-85 is pretty much glued onto my camera... 10-22 is for special circumstances (ie. not used very often).
Having overlap is not a bad thing. ;)
Kel
Gear
Nick_Reading.UK
Joined Nov 2011
Dec 03, 2013 02:13 |  #7
The question is.... Will you go Full frame at some point.. alot of us now on FF wish we had bought EF lenses from the start.. just my 2 cents
EOS 5Dmk3 X2, 60D, EF24-70mm f2.8L mk2, EF70-200mm f2.8L IS mk2, EF85mm f1.8, EF50mm f1.4, EF50mm f1.8 mk1(350D with 18-55mm Sh"kit" lens).
Speedlite 600EX-RT, 430EX II Flash. manfrotto 190XDB tripod, Giottos GTMML 3290B Monopod, B+W 77mm 110 Single Coated filter, Hama 77mm Variable Neutral Density Filter.
982 views & 0 likes for this thread, 6 members have posted to it.
1986 guests, 126 members online
