Thread started 04 Dec 2013 (Wednesday) 06:16
Question to Canon ST-E3-RT & 600EX-RT
NemethR
Joined Jun 2012
Dec 04, 2013 06:16 |  #1
So I was thinking on gettin g 2x 600 EX-RT, and a ST-E3-RT.
I just now discovered, that the ST-E3-RT unlike the ST-E2,
cannot fire an AF Assist beam.
Is it possible to let a remotly controlled flash use his built-in Beam?
(In case you are trying to make pictures in complete darkness).
OR is it possible to turn the 600EX-RT's flash completly off, and use it only for AF-Assist beam?
If none of the above is possible, can a ST-E2 fire off the 600EX-RTin "conventional" triggered by light mode?!
Thanks in advance!
Roland | Amateur Photographer
Nikon D850 | Nikon D80 | Nikon 70-200 f/2.8G ED VR II | Nikon 24-70 f/2.8G ED
Brea
Joined Nov 2013
Dec 04, 2013 06:49 |  #2
Doesn't matter if there is no assist beam. You can press the DOF button on your DSLR and as along as the flash is connected via TTL it will strobe a modelling light for about 1.5 seconds, letting you focus within that time period.
NemethR
Joined Jun 2012
Dec 04, 2013 07:21 |  #3
Brea wrote in post #16500430 (external link)
Thank you very much Brea, actually I did not even know about this funcion. :D
But there are some cases, when you should not "strobe".
(For example when photographing a Horse at night)
So I would still be interested in the above, if they are possible.
Nick5
Dec 04, 2013 09:22 |  #4
If you have a 600 EX-RT on camera and a second 600 EX-RT off camera, yes you can have the on Camera 600 Flash act as a Focus Assist and not fire Flash.
On Camera Flash as Master
Menu 2
First Option, Picture of Camera Flash 3 lines/ 0 Lines, Touch button underneath
As you tap button you will notice the Flash Icon just below the ETTL, Master Etc. not in menu bar options, will have 3lines or no lines as you tap.
Press your Flash Test button in each option and notice.
Hope this helps.
Canon 5D Mark III (x2), BG-E11 Grips, Canon Lenses 16-35 f/4 L IS, 17-40 f/4 L, 24-70 f/4 L IS, 70-200 f/2.8 L IS II, 70-200 f/4 L IS, 70-200 f/4 L IS Version II, 100-400 f/4.5-5.6 L IS Version II, TS-E 24 f/3.5 L II, 100 f/2.8 L Macro IS, 10-22 f3.5-4.5, 17-55 f/2.8 L IS, 85 f/1.8, Canon 1.4 Extender III, 5 Canon 600 EX-RT, 2 Canon ST-E3 Transmitters, Canon PRO-300 Printer
NemethR
Joined Jun 2012
Dec 04, 2013 09:47 |  #5
Nick5 wrote in post #16500732 (external link)
Menu 2
Hope this helps.
Thanks Nick, that helps, altough I do not yet have a 600EX-RT, but If I understand it properly, then the AF Assist beam fires, but the flash will not.
That is exactly something I need, (I do not understand why the ST-E3 RT does not have an AF assist beam :( )
But thank you very much for the info! 8-)
apersson850
Obviously it's a good thing
Gallery: 35 photos
Dec 04, 2013 10:06 as a reply to  @ Nick5's post |  #6
You can also use the optical system supported by the ST-E2. Your 600 EX-RT will then essentially mimic a 580 EX II.
Anders
mike1812
Dec 04, 2013 18:10 |  #7
You can also hold out for the Yongnuo equivalent of the ST-E3-RT (announced) that WILL have a AF assist beam included. It is my understanding it will be compatible with Canon's system, so that you can mix 600EX-RT's with the Yongnuo trigger and 600-equivalent flashes all with RT capability.
EF 135L | EF 70-300 L | ST-E3-RT | (4) Einstein E640s | Sekonic L-758 | Sony A7RII Gripped | Sony A7RIII Gripped | Sony 16-35GM | Sony FE 55 f/1.8 | Sony FE 85 f/1.4 GM | Sony FE 100-400GM | Sony 1.4x | Sony HVL-60M | Sigma MC-11 | Flashpoint Xplor AD600 | Flashpoint AD200 (2)| Flashpoint AD360 | plus too many doodads to list
dmward
Gallery: 29 photos
Dec 04, 2013 22:30 |  #8
mike1812 wrote in post #16502040 (external link)
According to THIS (external link) the Yongnou version is available within a few days. All the indications are that it has all the capabilities of the Canon ST-E3-RT plus AF assist and ability to support Gr mode in pre-2012 cameras. Both major omissions on Canon's part.
mike1812
Dec 05, 2013 11:20 |  #9
Good to know David. If these work as described, I'm betting we'll see a lot of ST-E3-RT (Canon) units on the "For Sale" forum pretty soon. I'm pretty sure I'm going to order one to test and will sell the Canon if it works as advertised (which is a good bet given Yongnuo's track record).
MFG
Dec 05, 2013 17:04 |  #10
yes, i have 2 x 600ex rt and 2 x st-e3.
in ourdoor, the radio trigger st-e3 works perfectly and i do not really need any assist beam to help in AF.
in indoor lowlight, you can (as mentioned) put a 600ex onto the hotshoe of your camera and "Disable" firing of flash. then the beam can help.
please note that if you are using the 2013 model then the focusing points fr the flash and the camera should be the same. if you using camera bodies before 2013, the flash may have more points than the body -> not much of a concern but gd to know.
Scott
AIPP Accredited (Australia), WPJA
Professional Wedding, Newborn and Family Photographer
https://www.scottgohph​otography.com.au (external link)
https://www.facebook.c​om/ScottGohPhotography (external link)
https://www.scottgohph​otography.com.au/blog (external link)
https://www.scottgohph​otography.com.au/babie​s-and-children/ (external link)
2,881 views & 0 likes for this thread, 7 members have posted to it.
1506 guests, 136 members online
