Obviously center image quality is tremendously important. But how important are mid-frame and border IQ to you guys?
I've been hunting for a longer lens that is affordable, and find most have "ok" mid and border sharpness/IQ, even when the center is close to excellent. I expect to use whatever I end up with at the longer end, so that's where I'm focusing my comparisons (excuse the pun). It seems that almost every xx-300mm lens out there falls short at the 250-300mm range (excluding the 70-300L which is not in the budget), especially in the mid-frame and border areas.
My long lenses for now are the EF-S 55-250mm, and an older Tamron AF 200-400mm. I find the 55-250 images to be lacking a bit in color and contrast, and the 200-400 lacking in the sharpness area. I'm sure the 200-400 was great for the 8MP bodies in it's day, but I feel I could do better.
Trying to stay within a budget of <$500. So far, I'm strongly considering the Tamron 70-300mm f/4-5.6 Di VC. I've also considered the 70-200 f/4L non-IS, but I'm pretty convinced I need image stabilization as I've found I'm just not that steady handed, and I tend to try and shoot tight, so cropping may/may not work for me.
What else should I look at?
