Thread started 07 Dec 2013 (Saturday) 17:15
Dropped lens, not focusing
Shooting
Dec 07, 2013 17:15 |  #1
I dropped my Canon 35mm EF f/2 lens on my carpeted bedroom floor and now AF and MF will not work.
Is it easy to repair myself or should I try to find someone to repair it? I really do not have the money to purchase another one at the moment.
shaftmaster
Dec 07, 2013 17:55 |  #2
Lack of both AF and MF sounds like something might be jammed versus an AF electrical problem. Hard to say if you could fix it yourself, but I would guess not unless you've fixed rather delicate mechanical things before.
I fixed a cheap EF35-80mm zoom that was jammed. It was not too tough to get it apart and then get it back together, but I didn't care much if it worked or not since I probably paid $15 for it.
If you fix it yourself it may need calibration afterward, and if you can't fix it you can probably sell it on eBay for maybe $100 as a "for parts or repair" lens.
Paul
Gear -- Flickr (external link)
Shooting
Dec 07, 2013 18:04 |  #3
Humm..I'm not that mechanically inclined so I'll pass on doing it myself, I have no idea of where to start. I have a quote from a place they will fix it for $105. If they in fact will do that, it may be worth it.
If not then I will try to sell it for parts like you said. thanks.
Hogloff
Joined Apr 2003
Dec 08, 2013 10:02 |  #4
Shooting wrote in post #16509534 (external link)
Make sure this place not only fixes it mechanically, but they also have calibration equipment on site. You might pay $105 and get a lens that will focus again, but be totally out of calibration.
gjl711
Dec 08, 2013 10:14 |  #5
The trouble is that until you open up the lens to assess the problem, no one can give you an answer. It could be something as simple as a stuck gear or lever arm, or it could be a broken wire, or it could be a blown board or something completely different. Opening and taking apart a lens is simple, pretty much if you can use a screwdriver, you can take a lens apart. Getting it back together and working properly is a bit tougher.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
waterrockets
Joined Jun 2010
Dec 08, 2013 10:21 |  #6
I dropped a 24-105 f/4L attached to a body. Not far, from a seat to a bus floor, and somehow it stopped focusing as well. No AF or MF.
This may help the OP: I discovered shortly afterwards that I was able to re-engage focus by racking focus very far in both directions, and it would eventually catch (only one or two tries in each direction). Once it catches, AF and MF work fine. It does stop working occasionally now, but racking focus always fixes it.
I've been thinking about popping it open to see if I can fix it myself...
1D MkIV | 1D MkIII | 550D w/grip & ML| EF 70-200mm f2.8L| EF 24-105mm f4L IS | Canon EF 100-400mm f/4.5-5.6L IS | Samyang 14mm f/2.8 IF ED UMC | 430EXii | EF 50mm f1.8
Shooting
Dec 08, 2013 10:34 |  #7
gjl711 wrote in post #16510766 (external link)
But I have no idea of what to look for. There are about 5 screws on the back I can take out and then what would I be looking for? I don't know the contents or what they should look like to determine if it is something I can "spring" back into place or not.
Shooting
Dec 08, 2013 10:37 |  #8
waterrockets wrote in post #16510781 (external link)
I'll tried that and the ring keeps turning non-stop. Is there a limit of how far it should turn? I'm doing this with the switch in MF and it is so hard to turn.
advaitin
Gallery: 434 photos
Joined Jun 2003
Dec 08, 2013 10:37 |  #9
Sometimes you have to bite the bullet and send it to Canon repair.
Canons to the left, Canons to the right,
We hold our L glass toward the light,
Digitizing in a snap reflective glory
That will forever tell our imaged story.
gjl711
Dec 08, 2013 10:52 |  #10
Shooting wrote in post #16510808 (external link)
My point was that if you don't know what you are looking for and not resonably confidant you can get things back together and have the lens still be calibrated, send it in.
::Gear::
Shooting
Dec 08, 2013 11:50 |  #11
gjl711 wrote in post #16510857 (external link)
That is true. Or since it is almost totally broken, get a rubber hammer to lightly bang around the ring and see if it releases something.
Shooting
Dec 08, 2013 11:51 |  #12
advaitin wrote in post #16510822 (external link)
True but I'll try not to do that, costs a lot. I'll have to weigh the pros and cons on it. No job, no photography jobs coming up so got to watch my pennies at the moment.
Shooting
Dec 08, 2013 20:55 |  #13
Well, I took a wooden handled knife and started firmly tapping the focusing ring all around a few times, turning, hitting, about 5 cycles and now it turns as smooth as anything and autofocuses now. Acts like it is fixed and I tried various ranges and all are in focus still so I guess it doesn't need any calibration. If it holds then it is fixed, if not - Canon here it comes. I got the estimate a few hours ago from them, about $109.00
xarqi
Dec 08, 2013 21:57 |  #14
Skillful fix! ;)
Shooting
Dec 09, 2013 17:53 |  #15
hahaha. Thank you. Who said ingenuity doesn't exist. I shot some today with it and it still works perfect.
4,526 views & 0 likes for this thread, 8 members have posted to it and it is followed by 2 members.
1693 guests, 139 members online
