Thread started 08 Dec 2013 (Sunday) 03:29
Canon 100mm f2.8L Macro USM question
StarJack
Dec 08, 2013 03:29 |  #1
I just received a Canon 100mm f2.8L Macro from Buydig. I've only taken a few test shots indoors at night, and they are quite sharp. However the USM (or something else in the lens) is loud, and I just wanted to ask if anyone else has experienced a problem with this lens being loud?
Oddly enough, the lens is making a lot of noise after the shot is taken, for a second or two, almost like it's is continually trying to focus, though it isn't, as it makes the same noise in manual focus mode. It almost sounds like a toy train engine (think N scale) after a picture is taken?!
I've never quite heard anything like it. :confused:
Regards,
Steve
kin2son
Joined May 2011
Dec 08, 2013 03:34 |  #2
That's just the IS noise...
5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
EOS M / EF-M 18-55 / EF-M 22f2 / Ricoh GR aka Ultimate street camera :p
Flickr (external link) | My Images on Getty®‎ (external link)
StarJack
Dec 08, 2013 03:55 as a reply to  @ kin2son's post |  #3
Thanks, the noise coming from the IS makes sense, so I'll re=phrase the question. Is it common for the IS on this lens to be a lot louder than the IS on other Canon lenses?
(I have the 28-135, 17-55 ef-s, 70-300 DO, and 24-105. None of which make even remotely as much noise as this lens.)
Regards,
Steve
Mashimaro
Dec 08, 2013 04:08 |  #4
yes, should be completely normal.
the IS on the 100L sounds very similar to my 70-200 II.
Canon 5D4 / Sony A7R2 / Leica M240
amkorp
Joined Oct 2012
Dec 08, 2013 09:26 |  #5
I find that the sound is much louder on my 100L than on any of my other lenses.
I also notice that this lens is very light and hollow feeling. Maybe this is one of the reasons why the IS is louder than normal.
5D Mark III | 50mm f/1.2L USM | 85mm f/1.2L USM | 100mm f/2.8L IS USM | 135mm f/2L USM | 8-15mm f/4L USM | 16-35mm f/2.8L II USM | 24-70mm f/2.8L II USM | 24-105mm f/4L IS USM | 70-200mm f/2.8L II IS USM | 70-200mm f/4L IS USM | 600EX-RT | 430EX II | 430EX | ST-E3 | EF 1.4x II | EF 2x III
amfoto1
Dec 08, 2013 09:48 |  #6
Steve,
Please clarify....
Is it a 100/2.8L IS?
That's not what you asked about... You asked about the other 100mm... Reading your post, it sounds as if you are using the non-L, non-IS lens. (Both lenses have USM. But the non-L, non-IS is often just called the "100/2.8 USM Macro", to distinguish it from an older version 100mm macro that was not USM. So there are three Canon 100mm macros: 100L or 100L/IS, 100/2.8 USM, and 100/2.8.)
If it is the IS version, then the noise you are hearing is pretty normal. The IS mechanisms in the L/IS version of the lens do make some noise, such as the gyros winding down even after you have taken the shot (or continuing to run if you still have the shutter release button half-pressed or the AF On button pressed).
If it is not the IS version, then the noise is not normal, something is wrong and you might be wise to ask for an exchange. The 100/2.8 USM is a pretty quiet lens... just very slight noises from the AF and aperture that are almost intantaneous and likely won't be heard over the camera's shutter.
amkorp
Joined Oct 2012
Dec 08, 2013 11:05 |  #7
the first post says
"I just received a Canon 100mm f2.8L Macro from Buydig." ..............
MDJAK
Dec 08, 2013 19:30 |  #8
Which means IS. The prior 100, as good as it is, is not an L and not IS.
The ­ F ­ stops ­ here
Joined Sep 2012
Dec 09, 2013 00:35 |  #9
Totally normal for the 100L. The IS is noisy.
Keep in mind this lens is listed as having a "hybrid IS" system, never looked too deeply as to what exactly that is, never cared enough too.
JD
Talent will get you far, but not as far as ambition
http://www.flickr.com/​photos/lenzfreak/ (external link)
Smugmug-primefocus.smugmug.com (external link)
sportmode
Joined Nov 2010
Dec 09, 2013 01:40 as a reply to  @ The F stops here's post |  #10
Just got mine too from buydig, and I do notice that the IS is louder than the 70-200.
5D Mark III, 6D, EOS-M 22mm f/2 | 24-70mm f/2.8L II | 50mm f1.4 | 100L | 70-200mm f/2.8L IS II | Rokinon 8mm Fisheye
StarJack
Dec 09, 2013 03:34 |  #11
Alan, yes this is the IS version of the lens, and the IS is what I am hearing (the noise stops when I switch IS off). Thanks everyone for taking the time to respond and confirm this is normal for this lens.
Regards,
Steve
2,691 views & 0 likes for this thread, 8 members have posted to it.
1065 guests, 115 members online
