Thread started 09 Dec 2013 (Monday) 07:58
looking to upgrade??
Giofazio44
Joined Dec 2013
Dec 09, 2013 07:58 |  #1
Hello im currently running two xti's with bg-e3 grips. there great little bodys but its time to upgrade. Im undicided between a 1d mkii n or 40d. I know there two completely different worlds. I try to shoot sports but i hardly get that "shot" because of the 3fps on the xti. I used a friends 40d and that seems to get the job done i like the feel in the hands and a lot of new features compared to the xti or the 1d mkii n. I dont know which way to go older pro or newer semi pro?? please helppp
NJ
G.M.F Photography
1DmkIIn/40D BG-E2N/SL1/XTi BG-E3/EOS 3/70-200 f4 Lusm/24-105mm F4L/17-40mm f4 "L"usm/100mm macro/20-35mm/28-135mm IS USM/50mmf1.8/70-300mm IS USM/430exmkii/ST-E2
gjl711
"spouting off stupid things"
Dec 09, 2013 08:08 |  #2
Step #1, set your price range. What are you looking to spend.
Step #2, your options will present itself from the price you are willing to spend.
But as your looking at the 40D, I'm guessing that the price range is going to be quite low. Having had both the XTi and the 40D, there is little difference outside of a few things like frame rate. It's really not much of an upgrade. I would seriously set the low end at either the 50D or the 1DIII as minimums.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Giofazio44
Joined Dec 2013
Dec 09, 2013 08:27 |  #3
gjl711 wrote in post #16513008 (external link)
I dont really need to get a new body. I was just looking around and the 1d mkii n and 40d both seems rather inexpensive, so thought there cheap lets get a newer body so i really didnt have a set price range. What body would you suggest if i shoot sports-wildlife take it to the city?? and didnt want to spend to much???
NJ
G.M.F Photography
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Dec 09, 2013 08:41 as a reply to  @ Giofazio44's post |  #4
At the very minimum, I would upgrade the XTi to the 50D, or if a 1D series is being considered, the 1D3.
Chopper ­ Al
Dec 09, 2013 11:16 |  #5
I've had both the XTi, XSi, T2i, 40D and the recently purchased 60D. By far, I prefer the 60D out of all of them. I got my 60D for a rediculous low price because it needed repair. Bought the $30 part, repaired it myself and now things are golden. Just my 2 cents.
Giofazio44
Joined Dec 2013
Dec 09, 2013 11:21 |  #6
Chopper Al wrote in post #16513459 (external link)
How do you like 60D?? is there a noticeable difference in the fps between the 40D and the 60D???
NJ
G.M.F Photography
danielb59
Joined Jun 2012
Dec 10, 2013 09:29 |  #7
Was shooting with my 6D and 24-105 on a tripod. Several shots were excellent and then, all of a sudden, it just stopped focusing. I know something is amiss, but the only thing I can figure is that I left the stabilizer on while using the tripod. Error on my part. Looks as though the lens just stopped focusing. My subjects have flown the coop and it will be a while before I can recheck. When I removed the 6D from the tripod, it worked fine. I might try an 85, which does not have stabilization when they return. My testing results in great images with the 24-105.
Any suggestions would be appreciated.
Dan
6D, 60D Gripped, Rokinon 7.5, Canon 24-105 4.0 L, Canon 50 1.8, Canon 85 1.8, canon 17-40 4.0 L, Sigma 17-70 2.8-4, Canon 100 2.8 L macro, Tamron 70-300 4-5.6, Sigma 170-500 5-6.3
sourcehill
Gallery: 19 photos
Joined Aug 2013
Dec 10, 2013 10:09 |  #8
Giofazio44 wrote in post #16513477 (external link)
The 60D will overall be a little bit quicker than the 40D.
Less noise at high ISOs...better IQ but not by much. The 60D isn't built as tough at the 40D but I would take it over the 40D if I had the choice. The control layout is a bit different too.
I like gear and I have too much.
Check out my current work on Instagram @immichaelcarmen
redwoodandrye.com
1,121 views & 0 likes for this thread, 6 members have posted to it.
911 guests, 162 members online
