Thread started 11 Dec 2013 (Wednesday) 08:20
Looking into macro???
Giofazio44
Joined Dec 2013
Dec 11, 2013 08:20 |  #1
hello im interested in macro ive done macro for a little using macro extenders on my 28-135 is usm. I got the extenders because they were inexpensive and i wasnt 100% sure i would like macro, now that ive been doing macro for a little i love it. its time to get a real macro lens any sugestions on what lens to look at????
NJ
G.M.F Photography
1DmkIIn/40D BG-E2N/SL1/XTi BG-E3/EOS 3/70-200 f4 Lusm/24-105mm F4L/17-40mm f4 "L"usm/100mm macro/20-35mm/28-135mm IS USM/50mmf1.8/70-300mm IS USM/430exmkii/ST-E2
archer1960
Gallery: 6 photos
Dec 11, 2013 08:25 |  #2
Something around 100mm is the usual starting place: Sigma 105, Tamron 90, Canon 100. Which one depends on your budget and brand perferences; the Canon 100 non-L is about $500 cheaper then the L, but doesn't have IS. The Sigma and Tamron are both stabilized. They all have very good optics, and make fine portrait and general-purpose short telephoto lenses as well.
If you're into extreme macro (>1x magnification), the Canon MP-E is the only real choice, and it has a steep learning curve, is not stabilized, is manual focus only, and can't focus to infinity. But it opens up a whole new world if that is the world you're interested in.
Gripped 7D, gripped, full-spectrum modfied T1i (500D), SX50HS, A2E film body, Tamzooka (150-600), Tamron 90mm/2.8 VC (ver 2), Tamron 18-270 VC, Canon FD 100 f/4.0 macro, Canon 24-105 f/4L,Canon EF 200 f/2.8LII, Canon 85 f/1.8, Tamron Adaptall 2 90mmf/2.5 Macro, Tokina 11-16, Canon EX-430 flash, Vivitar DF-383 flash, Astro-Tech AT6RC and Celestron NexStar 102 GT telescopes, various other semi-crappy manual lenses and stuff.
Jerobean
Dec 11, 2013 08:26 |  #3
What is your budget, what do you want to shoot, will the shots be taken handheld or on tripod?
100 2.8L IS will be the default answer.
6d, 24-105L, Tak SMC 50 1.4, 85 1.8, 135L
Giofazio44
Joined Dec 2013
Dec 11, 2013 08:36 |  #4
archer1960 wrote in post #16518480 (external link)
i was looking into the efs 60mm macro
NJ
G.M.F Photography
Giofazio44
Joined Dec 2013
Dec 11, 2013 08:37 |  #5
Jerobean wrote in post #16518482 (external link)
i dont really have a budget i was just trying to get an idea of where to look.. probally both
NJ
G.M.F Photography
ceegee
Dec 11, 2013 10:16 |  #6
Giofazio44 wrote in post #16518508 (external link)
Outstanding lens, tailor-made for crop cameras, extremely sharp, does everything well. I love mine.
Gear: Canon R10, Canon RFS 18-150, Canon RF 100-400
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Dec 11, 2013 10:22 |  #7
Giofazio44 wrote in post #16518471 (external link)
Heya,
I would get the Canon EF 100mm F2.8. Cost is consumer friendly. Quality is very close to the top stuff. High performing for cost. Works on any Canon dSLR, so you're not limited in the future if you change bodies. Re-sale is great, because it works on all Canon dSLR's and is a staple for mid-tier macro setups. Smartest "lens" for this in my opinion.
As an alternative, I would look to the 90mm Tamron.
Don't forget a good flash setup, either way.
Very best,
gnome ­ chompski
Joined Jun 2013
Dec 11, 2013 10:25 |  #8
great lens. know that its only usable on crop sensor camera's. if thats not a concern, use with confidence.
Tumblr (external link)
Instagram (external link)
Giofazio44
Joined Dec 2013
Dec 11, 2013 10:52 |  #9
ceegee wrote in post #16518782 (external link)
and its not that expensive :)
NJ
G.M.F Photography
Giofazio44
Joined Dec 2013
Dec 11, 2013 10:54 |  #10
MalVeauX wrote in post #16518802 (external link)
Heya,
Very best,
hello
good point that if i change bodies no longer can use the 60mm i completely forgot about that. thanks Valmeaux
NJ
G.M.F Photography
Giofazio44
Joined Dec 2013
Dec 11, 2013 10:56 |  #11
gnome chompski wrote in post #16518813 (external link)
i forgot about the crop factor :mad:
NJ
G.M.F Photography
archer1960
Gallery: 6 photos
Dec 11, 2013 10:56 |  #12
I second the point on the flash. It's vital for anything other than bright sunlight shooting.
xarqi
Dec 11, 2013 16:36 as a reply to  @ archer1960's post |  #13
Giofazio44 wrote in post #16518886 (external link)
Crop factor, as it is usually applied, is nearly irrelevant for macro (and much else in my opinion).
All of the lenses mentioned can give you 1:1 reproduction, that is, the image that falls on the sensor is the size of the real object. What changes with focal length is the distance you can be from the subject to achieve this.
archer1960
Gallery: 6 photos
Dec 11, 2013 16:45 |  #14
xarqi wrote in post #16519817 (external link)
Yup. With the 60, you're going to be significantly closer to get the same size image on your sensor. With flowers and inanimate objects, that usually doesn't matter, but with skittish bugs, it can make it more difficult to get the shot you want. If you need a LOT of stand-off distance, Canon, Sigma and maybe Tamron all make longer f/l Macro lenses. Canon's is 180mm; I think Sigma might be 150, though I'm not sure. These are bigger, heavier and more expensive than the 100mm range, but give you significantly more stand-off distance if you really need it.
gnome ­ chompski
Joined Jun 2013
Dec 11, 2013 16:47 |  #15
Yes, but the 60mm lens is an ef-s lens. All the others are EF.
2,623 views & 0 likes for this thread, 9 members have posted to it.
910 guests, 162 members online
