Would a mount wear off after excessive lens changing? I've been reading online and there was this case of a Nikon lens falling off and breaking. What about canon? Especially the rebel series?
Ev0d3vil Member 87 posts Joined Dec 2013 Location: Singapore More info | Dec 15, 2013 21:03 | #1 Would a mount wear off after excessive lens changing? I've been reading online and there was this case of a Nikon lens falling off and breaking. What about canon? Especially the rebel series?
xarqi Cream of the Crop 10,435 posts Likes: 2 Joined Oct 2005 Location: Aotearoa/New Zealand More info | Dec 15, 2013 21:50 | #2 Naaaa - can't see it myself. Maybe, just maybe, some of the plastic lens mounts could suffer, but not the metal ones, not from wear alone.
KirkS518 Goldmember 3,983 posts Likes: 24 Joined Apr 2012 Location: Central Gulf Coast, Flori-duh More info | Dec 15, 2013 22:05 | #3 One thing you have to remember is that many of the bodies themselves are plastic. The mount may be metal, but what the mount gets screwed into is plastic, or a female thread embedded in plastic. I can see it happening. If steroids are illegal for athletes, should PS be illegal for models?
Dec 15, 2013 23:10 | #4 Ah cause I'm shooting occasionally at high rise areas and I don't want to entertain the possibility what if my lens fell off my camera body because of a faulty mount..
xarqi Cream of the Crop 10,435 posts Likes: 2 Joined Oct 2005 Location: Aotearoa/New Zealand More info | Dec 15, 2013 23:15 | #5 Well, if you want to be as secure as you can be, there are strap systems that allow independent restraint of the body and the lens. There was a recent thread on this - I'll see if I can find it.
BillBoehme Enjoy being spanked More info | You can be absolutely certain that if a lens falls off that the cause is due to a loose nut on the back of the camera. Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
xarqi Cream of the Crop 10,435 posts Likes: 2 Joined Oct 2005 Location: Aotearoa/New Zealand More info | Dec 15, 2013 23:20 | #7 Here's the thread, for what it's worth: https://photography-on-the.net …/showthread.php?t=1346429
Dec 15, 2013 23:36 | #8 Ev0d3vil wrote in post #16530368 Would a mount wear off after excessive lens changing? I've been reading online and there was this case of a Nikon lens falling off and breaking. What about canon? Especially the rebel series? The chance of that happening was engineered out of existence when Canon switched to the EF lens mount
Dec 15, 2013 23:42 | #9 I can see that happening after about 14.679 lens changes. Canon 5D Mark III, Canon 6D, Canon 24-70 F/2.8L, Canon 70-200 F/4L IS, 135mm 2.0 L, 85mm 1.8, Speedlite 430 II.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Dec 16, 2013 11:10 | #10 Metal-to-metal contact does cause wear of the surfaces...the piston rings on the cylinder walls of your automobile engine are an example: You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Dec 16, 2013 11:24 | #11 Wilt wrote in post #16531572 150000 miles at 2500rpm, plus overhead of engine running at stop lights at 800 rpm, might be 1400 Million up-down rubs of the piston rings against the cylinder walls of a 4-stoke engine. It takes a lot of rubbing!
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Dec 16, 2013 11:49 | #12 Right, you are. OTOH lens mount friction is low, and the rate of speed of rub is a bit slower than inside the engine! And, most likely, the number of rubs is greatly diminished...but digital photographers are a pretty crazy lot for number of exposures in a year! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | Dec 16, 2013 12:32 | #13 It is possible, but highly unlikely. Alan Myers
vimwiz Mostly Lurking 17 posts Joined Dec 2013 More info | Dec 19, 2013 01:59 | #14 Agree with amfoto1 KirkS518 wrote in post #16530505 One thing you have to remember is that many of the bodies themselves are plastic. The mount may be metal, but what the mount gets screwed into is plastic, or a female thread embedded in plastic. I can see it happening. Probably unlikely in the lifespan of a digital camera, provided you dont go mad with swapping all the time.
| Latest registered member is MWCarlsson 1006 guests, 186 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
