What are you using for your pp work? The only problems I see is the upper chest and the foot. One trick I use in PS5 is to go to selective color, select neutrals, neutrals only and slide back anywhere between -5 and -15. I keep three presets, -5, -10 and -15, rarely use -15 and most commonly use -5 It does darken and bring out more contrast but it makes the bird pop like you are looking for. Black and white birds can be very hard to expose on. Many disagree with me but I always shoot one full stop underexposing to control those hot whites, unless it is very cloudy with no sun, you can almost always bring back the brightness and compensate for the contrast from the neutral adjustment with brightness and contrast. Give it a go and see what you can do. It may bring back the real hot white chest and darkens the background to kind of separate the background from the subject. A smooth background, they love to laugh at you with lots of sticks in the area, helps them stay away from the Hawks too.. well, that is up to the bird to allow you such a pretty background unless you have it setup in the yard. Good Luck
