Thread started 16 Dec 2013 (Monday) 12:32
Who changed my RAW setting? 1D Mk IV
BigSkyKen
Dec 16, 2013 12:32 |  #1
OK, I know this is going to sound like a really stupid question, but I've got to find out if this has happened to others. I purchased my gently used 1D Mk IV early last March. I set the file type to RAW only (the big one), as I don't have any use for the sRAW or mRAW files. So I did a fair amount of shooting since then, but recently came to the realization that my files were not as large as they should be...upon closer inspection I see that I've seen shooting sRAW since early April.
No one else uses my equipment, so if this didn't happen on its own, I had to do it. But there would be absolutely no reason for me to make that change, so it would have been an error on my part. I guess I really am hoping that I screwed up, because the thought of having to check the file format every time I shoot would be aggravating if my camera has a mind of it own!
BigSkyKen
Wildlife & Nature Blog @ His Creation (external link)
M_Six
Gallery: 64 photos
Dec 16, 2013 12:46 |  #2
I don't own a Mk IV (yet), but on my other bodies I've accidentally changed that setting in Q mode. Does the Mk IV have a Q mode for settings?
Mark J.
Gear
Sgt.Ed
Dec 16, 2013 13:01 as a reply to  @ M_Six's post |  #3
Just a thought as this has not happened to me. When you did your initial set up of the camera it is possible that you moved the selection box to RAW but did not push the "set" button to actually make the selection. The camera would retain the previous setting and you would have thought it had been changed.
Ed
Ed
GEAR40D, 1D MKIV, 24-70 f2.8L, 70-200 f2.8L, 500 f4.0L, Canon 1.4 teleconverter, 580 EXII Speedlite, Gitzo GT 3530LS, Wimberly WH-200, 190X PROB Manfrotto tripod and a bunch of other stuff
MYFlickr (external link)
BigSkyKen
Dec 16, 2013 13:18 |  #4
Sgt.Ed wrote in post #16531874 (external link)
Ed
Ed, I set up the camera in early March, and it looks like every image for nearly 30 days was the large RAW file, so I must have pushed the 'set' button. I know what you mean though, because I've failed (on numerous occasions) to push 'set' when changing settings for AEB! Something changed after I owned it for about a month, and every image afterwards is sRAW.
BigSkyKen
BigSkyKen
Dec 16, 2013 13:22 |  #5
M_Six wrote in post #16531821 (external link)
Nope, no Q mode. But the file type can be changed from the 'FUNC' button under the lower info window on back of the camera. Would have had to push that button, then roll the rear dial 4 places clockwise to make the change. I can see where I may have unknowingly pressed the FUNC button prior to rolling the dial for some other purpose...not saying that is what happened, but sure could have happened.
BigSkyKen
Snowyman
Gallery: 428 photos
Joined Oct 2011
Dec 16, 2013 13:32 |  #6
C.Fn IV -4 – Assign SET button
In the default configuration, the SET button has no function. However, you can assign functions to the SET button to make them quicker or easier to access. There is a choice from seven settings that can be applied. If you apply one of the settings, pressing the SET button will bring up the setting screen on the rear LCD panel.
0: Normal (disabled)
1: White Balance
2: Image Size _______________Anything but this!
3: ISO Speed
4: Picture Style
5: Record func + media/folder
6: Menu display
7: Image playback
Wasteful use of a perfectly good button!
Snowy's Gear
Deviant Art (external link)
500px (external link)
Alan ­ B
Gallery: 40 photos
Joined Dec 2004
Dec 16, 2013 13:40 as a reply to  @ Snowyman's post |  #7
From RAW it takes 10 clicks left or right on the control wheel to get to sRAW(just tried it on mine lol).
Weird situation ?
BigSkyKen
Dec 16, 2013 14:08 |  #8
Snowyman wrote in post #16531961 (external link)
Thanks Snowy. I checked and it is set to 0 - Disable
BigSkyKen
BigSkyKen
Dec 16, 2013 14:09 |  #9
Alan B wrote in post #16531983 (external link)
Weird situation ?
You're correct. 4 clicks get me to Small jpeg plus RAW. 10 clicks gets to sRAW...making this a less plausible occurrence.
BigSkyKen
Alan ­ B
Gallery: 40 photos
Joined Dec 2004
Dec 16, 2013 14:21 as a reply to  @ BigSkyKen's post |  #10
Was your 1DMkIV brand new or was it second hand ?.
The only thing I can think of is you can register 9 basic settings so you can quickly revert back to them ie
- Shooting Mode
- White Balance
- Drive Mode
- Metering Mode
- AF Mode
- AF Point
- Color Space
- Image Size
- Picture Style
These can be changed simultaneously with a single operation.
Worth a check ?
lovemyram4x4
Gallery: 97 photos
Joined Mar 2013
Dec 16, 2013 14:59 |  #11
Registered settings surely sounds like a plausible cause. I inadvertently applied basic settings while registering once and went out shooting birds for 2 days before I noticed I was set to jpeg instead of RAW.
BigSkyKen
Dec 16, 2013 15:33 as a reply to  @ lovemyram4x4's post |  #12
It was used when I got it, and it looks like Set 1 has some custom functions registered, but I can't figure out how to determine what those setting are. Will have to study the book to get much further on this. Thanks for the idea guys.
BigSkyKen
El ­ Pedro
Joined Sep 2012
Dec 19, 2013 13:45 |  #13
One of the four buttons above the small lower screen can be used to change image size. I'd say this would be more likely to have been accidentally pressed rather than being switched in menu.
Alan ­ B
Gallery: 40 photos
Joined Dec 2004
Dec 19, 2013 13:50 |  #14
El Pedro wrote in post #16540258 (external link)
Even when pressing that button on the back, you still have to turn the control wheel left or right 10 clicks to get from RAW to sRAW.
I still think it was what I said! ?.
Wonder if he ever found out what is was ?
BigSkyKen
Dec 19, 2013 16:24 |  #15
No, I haven't figured out how to see what is registered. Thinking of setting all to default and starting over. The darn manual isn't the best guide for things like this.
BigSkyKen
1,962 views & 0 likes for this thread
Latest registered member is lamacchiacosta
863 guests, 258 members online
