Thread started 17 Dec 2013 (Tuesday) 12:10
Does the EF600mm f/4L USM have a protective front filter?
Madweasel
Dec 17, 2013 12:10 |  #1
I'm talking about the original EF600mm, non-IS. I know the later ones definitely have a flat front element that protects the lens elements, but can't find the details on the original. The Canon Camera Museum doesn't say (and doesn't give a block diagram).
I'm considering one that has some marks on the front, but if it does indeed have a flat front element it might be relatively cheap to replace (if they are still available). Any help appreciated.
Mark.
lens ­ pirate
Dec 17, 2013 14:28 |  #2
Madweasel wrote in post #16534509 (external link)
It also might not even be useful to replace it. Chances are those marks have zero impact on image quality.
INSANE GEAR LIST
Sun flare.... the new selective color. JUST SAY NO
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Dec 17, 2013 15:34 |  #3
ther parts catalog probably doesn't help much, but worth a look anyay:
http://www.micro-tools.net …20600%204.0%20L​%20USM.PDF (external link)
TF posting: here :-)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Dec 17, 2013 15:47 |  #4
Use the damage to talk the price down even further then don;t worry about it unless it's really ghastly.
Likewise, if your serious about either the purchase or the repair, I'd get an actual price. You might find that the cost of replacement is too much,. this info again would be helpful in getting the lens and learning to live with the damage.
CDS' HOT LINKS
Madweasel
Dec 17, 2013 17:28 |  #5
Thanks all for responses. joeseph, the parts catalogue, and especially the diagram it includes, does show a flat front piece, though I take the other points, that the marks are probably best used to possibly reduce the already reasonable price, and not really worry about their effect on image quality. I'll be looking at it in the flesh tomorrow. Wish me luck!
Mark.
Madweasel
Dec 18, 2013 17:00 as a reply to  @ Madweasel's post |  #6
Well I went to see it and the marks were not nearly as bad as I'd feared, so no worries about the front element. There is a mark on one of the rear elements (but not the drop-in filter), so I did some tests outside the shop.
This was an extreme test for flare, with a very bright light source and dark background. I certainly don't see any cause for concern here, with only a tiny bit of flare visible towards the bottom centre.
IMAGE: http://i72.photobucket.com/albums/i192/garlicpickle/Canon/lr1small-3978_zps44317ad2.jpg
I took this one looking across the road at a display in a shop (so shooting through the other shop's window). This is handheld at 1/200 (no IS remember - I reckon the inertia of the lens holds it steady), using 5DII, so I could check the whole frame area.
IMAGE: http://i72.photobucket.com/albums/i192/garlicpickle/Canon/lr1small-3979_zpsa30ba1e2.jpg
And finally a shot looking down the street at a road sign, so focus should be good. This was at twilight, so 1/250 (handheld), f/4, ISO 12800, but the sharpness is very impressive, right out to the corner. I'm really happy, but it is mighty heavy!
IMAGE: http://i72.photobucket.com/albums/i192/garlicpickle/Canon/lr1small-3981_zps34ded6fb.jpg
Mark.
commonjunks
Dec 18, 2013 18:11 |  #7
No there is no front filter for 600mm.
My friends customize Tupperware cover to fit as protection when transporting around.
5D3|35L|50f1.8II|580EXII
amfoto1
Dec 18, 2013 19:11 |  #8
The 600mm non-IS and IS "Mark I" both have a "plain" front element.... some refer to it as a "replaceable plain element", much as they think of the UV filters they stick on their other lenses.
It's part #CN2-1211 in the non-IS version of the lens.
I've heard this described both ways... as a lower cost "protective" element... but also as an actual optical element that serves purposes other than just "protection". I tend to think the latter is true, that it's not really only a protective element.... After all, what would Canon's incentive be, to design a "lower cost" replaceable element? They don't worry about keeping repairs affordable on other items. Why would they worry about doing so for one of the most expensive lenses in their line-up? Not to mention, the latest and most expensive to date - the 600/4 Mark II - no longer has that "plain" element. It's been dropped from all the Mark II lenses, I think.
Anyway, if you can't find a replacement or if the cost of it is too steep and it's merely a protective element you might be able to just remove it and use the lens without it. I suspect that the image quality might be effected, though... i.e. that the "plain" element is more than just a protective piece of glass. I suppose it would be relatively easy to remove it and try it.... can always put it back if IQ drops off without it.
2,570 views & 0 likes for this thread, 6 members have posted to it.
1076 guests, 114 members online
