Camera - 5Dm3
Flash - YN 568 EXII
Triggers - YN-622
In the camera's flash menu, under Flash Function Settings, If I leave HSS on, does it only kick in above 1/200 or will HSS functionality be enabled at every shutter speed if I leave it enabled?
If the later, I should disable when not in use so I'm not losing power?
