Thread started 20 Dec 2013 (Friday) 09:59
Eos 1100D Blurry Video
gingerjoe
1 post
Joined Dec 2013
Dec 20, 2013 09:59 |  #1
Hey All,
Recently purchased a E1100D and i've been finding that the videos are coming out quite blurry. (Example Here (external link))
Obviously its an entry level model but I was expecting the image quality to be higher.
Is there something I should be fiddling around with in the settings or is there something else I need to do?
Cheers
Joe
J_O_S_H_U_A
Joined Jul 2011
Dec 28, 2013 17:56 |  #2
There could be a number of factors that contribute to the "less than ideal" video quality.
At first glance your video looks out of focus. Perhaps your aperture is close to wide open and your depth of field is very shallow?
Bringing in some lights would allow you to control your shooting settings better.
www.instagram.com/_j_o​_s_h_u_a_ (external link) www.atomiccanary.com (external link) http://joshuaorozco.co​m (external link)
Jarvis ­ Creative ­ Studios
Gallery: 28 photos
Joined Aug 2013
Dec 28, 2013 18:03 |  #3
I also agree with Joshua that you should incorporate better lighting. Try having someone sit where you would be sitting, focus in on them so you can see how the focus looks as it's happening. That will help you determine if it's a camera or an operator issue. Also note that the 70D is the only camera that can autofocus after you start recording, so make sure if you're using AF you focus in before you hit the capture button.
WEBSITE (external link)
Sony ZV-1 || Sony a7RIV || Sony a9 || Sony a1 || Sony FE 20mm f1.8 G || Sony FE 24-70 f2.8 GM || Sony FE 50mm f1.2 GM || Sony FE 90mm f2.8 Macro G OSS || Sony FE 135mm f1.8 GM || Sony FE 200-600 f5.6-6.3 G OSS || Godox speedlights and strobes
mesakid
Dec 29, 2013 15:17 |  #4
Focus is off. Turn off the AF switch to MF and use the manual focus ring on the lens to focus on the subject. Also find a way to keep your ISO values down or use a faster, large aperture lens to get more light.
https://www.youtube.co​m/that1cameraguy (external link)
A9|A7RIII|A6500|A6400|​A6300|A6000
LostViet408
Joined Apr 2012
Dec 30, 2013 21:11 |  #5
Anything you shoot in video, use Manual mode. Manual mode lets you adjust Aperture, ISO, and shutter speed. Also make sure you're in focus by turning your ISO high enough to see yourself in the video and adjust the focus ring and then adjust your ISO accordingly to your lighting situation.
If you don't have enough lightning, you can also buy an external light source for around 25-30$. Buy an LED external light with 5600k color temperature.
I hope that helps.
Feedback
sspellman
Dec 31, 2013 00:34 |  #6
You need to focus carefully and in full manual mode with video before you start to record. Many people use an LCD viewfinder to more easily check focus like this:
http://www.ebay.com …_0&hash=item2c7​9680e0dYou (external link)
You can also get more of the scene in focus with a smaller aperture such as f5.6-12 and focus issues will be less of a problem. You can often do this with higher ISO or adding video lights.
-Scott
ScottSpellmanMedia.com [photography]
John ­ Sims
Dec 31, 2013 06:26 |  #7
All very solid comments. You could also consider an external mic or recorder to improve the audio.
Framing isn't great and you should also consider the background.
Many little things can elevate a video from something that might as well have been shot on a web cam to something you can be proud of. Your camera has the potential to do a great deal better.
John Sims
Canon 60D, 30D, 10D, AE1 & some other stuff
Azathoth
" ...whose name no lips dare speak aloud"
Gallery: 692 photos
Joined Jul 2012
Jan 07, 2014 14:08 |  #8
LostViet408 wrote in post #16565625 (external link)
I hope that helps.
You don't have manual exposure on video with the 1100d. So you can't adjust Aperture, ISO or shutter speed.
500px (external link) | flickr (external link) | Facebook (external link) | Instagram (external link) | Blue Jimny Madeira (external link)
LostViet408
Joined Apr 2012
Jan 09, 2014 11:29 |  #9
Azathoth wrote in post #16585864 (external link)
Ah, got it. I just thought every camera has manual mode. Good to know.
Feedback
5,975 views & 0 likes for this thread, 8 members have posted to it.
1680 guests, 136 members online
