I am looking for a fairly easy and realistic way to replace a sky in CS6. Can you suggest a tutorial? Thank you.
cerett Senior Member 824 posts Likes: 240 Joined Jun 2013 Location: Santa Ana, California More info | Dec 22, 2013 11:22 | #1 I am looking for a fairly easy and realistic way to replace a sky in CS6. Can you suggest a tutorial? Thank you. https://www.martinfeldmanphotography.com
Packhorse-4 Senior Member 425 posts Joined Jul 2006 Location: Missouri More info | Dec 22, 2013 11:39 | #2 Check out some of the tutorials on youtube - here is a quick link to one example: https://www.youtube.com/watch?v=EcJhVpx_1jg
cerett THREAD STARTER Senior Member 824 posts Likes: 240 Joined Jun 2013 Location: Santa Ana, California More info | Dec 22, 2013 11:47 | #3 Packhorse-4 wrote in post #16546979 Check out some of the tutorials on youtube - here is a quick link to one example: https://www.youtube.com/watch?v=EcJhVpx_1jg This can be a fairly simple edit or a very complex edit, depending on the image. A great big open sky over the ocean, with nothing obstructing the sky is pretty straight forward, but trying to replace the sky in an image with lots of trees (where the sky is visible throughout the leaves and branches) can be a bit more challenging. You may also want to look into some different selection techniques to select bits and pieces of sky coming through the trees if this is an issue for your image. Thanks John. That's encouraging. Went to the beach early this am anticipating a beautiful sunrise. Didn't happen - not a cloud in the sky.The rocks and surf in the foreground came out great. Used a 6 stop ND. Hopefully, I can replace this less than dramatic sky with something I shot last week. https://www.martinfeldmanphotography.com
M_Six Cream of the Crop More info | Dec 22, 2013 13:26 | #4 Beach shots should be easy enough. If you have Photoshop, the "Blend If" sliders can work wonders for sky replacement even if you have trees in the shot. Mark J.
| Latest registered member is semonsters 1098 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
