mike325 wrote in post #16547415
Hey all. I have been having some difficulty shooting static birds in trees with my new to me 70-200 f4 non is. I always feel like the camera is focusing on the tree branches I am aiming through, even though I am on center point focus and there are close branches, but not directly in the way.
Is this an issue that others have experienced? I played with the lens outside of trees and it works fine, so I'm guessing its just the fact that there are too many branches in the frame.
Thanks.
Small moving branches in front of a stationary bird will play havoc on an autofocus system. They're just not that smart. I usually just manual focus at that point. Unfortunately the center dot method with autofocus will still have trouble because frankly, the center "box" is going to have a hard time figuring out if you want the edge of a branch or the bit of bird. You have to be very, very close with 200mm on a small bird in a tree, to actually fill the frame and make it easy for the autofocus to really hone in on just the bird. Depth of field comes into play here too. Wide open, you may find you miss focus a touch. Stop down to F8 or F11 and you may see focus/sharpness happen on those little birds better.
Very best,
