Thread started 22 Dec 2013 (Sunday) 18:04
Quick AF Microadjustment question
Nick_Reading.UK
Joined Nov 2011
Dec 22, 2013 18:04 |  #1
Does the + move the focus in front of the subject and the - behind the subject? Or the other way round?
See what I am thinking is... That if you adjust to focus a couple of mm in front of subject you might get a better in focus keeper rate, but of course this will not work in a really shallow DOF Situation. Anyone else thought about this?
EOS 5Dmk3 X2, 60D, EF24-70mm f2.8L mk2, EF70-200mm f2.8L IS mk2, EF85mm f1.8, EF50mm f1.4, EF50mm f1.8 mk1(350D with 18-55mm Sh"kit" lens).
Speedlite 600EX-RT, 430EX II Flash. manfrotto 190XDB tripod, Giottos GTMML 3290B Monopod, B+W 77mm 110 Single Coated filter, Hama 77mm Variable Neutral Density Filter.
JeffreyG
Gallery: 41 photos
Dec 22, 2013 18:29 |  #2
+ puts the plane beyond the subject.
Curious, why do you think setting it to front focus a bit will make it more accurate? My experience is that setting it to be perfect yields the most accuracy.
Gobeatty
Joined Aug 2013
Dec 22, 2013 18:33 |  #3
Nick_Reading.UK wrote in post #16547664 (external link)
I believe it's the other way around. That is, + moves the focus point farther from the camera and - moves the focus point closer. If you have a setup that gives you a clear result of where the focus point is, a few test shots at 0 then + and - 10 should show clearly which way it goes. If you don't have a test setup that shows clearly where focus and dof are, may be better not to fiddle with micro adjust.
I did consider along the lines you are. I almost always focus to a front part of my subject so why throw away DOF in front of this point. It might be worthwhile in very specific set ups (specific lens, portraits, known f stop, at a specific distance) but in the end I decided it wasn't worth sacrificing sharpest focus at my focus point, especially as you noted with fast lenses wide open. I have heard of photographers setting the camera to focus back a bit for exactly this reason. Perhaps someone more knowledgable will chime in.
6D | 35 f2 | 50 1.8 | 85 1.8 | 28 - 135 f3.5 - 5.6 | 70-210 f4
Nick_Reading.UK
Joined Nov 2011
Dec 22, 2013 18:34 |  #4
JeffreyG wrote in post #16547697 (external link)
Not more accurate, just maybe more of a keeper rate, example if you focus on a tip of someone's nose but move the camera a fraction then the tip of the nose might be out a little.. Just thoughts nothing else.. :-)
hollis_f
Dec 23, 2013 03:51 |  #5
Nick_Reading.UK wrote in post #16547703 (external link)
Or, you could move the camera a fraction in the opposite direction and burger it all up even more :confused:
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
1,113 views & 0 likes for this thread
Latest registered member is LVBC90
948 guests, 241 members online
