Thread started 03 Feb 2006 (Friday) 18:52
Software used to frame pics?
austinjames
Feb 03, 2006 18:52 |  #1
I've noticed many of the pictures posted on the various forums here have picture style frames added to them to enhance the presentation. What software is being used to do this....does the adobe elements program have an option to do this? Thanks
Canon 5D3,
Canon 70-200 2.8L, 70-200 4.0L, 24-105, 135 2.0, 500mm IS
http://wildlifeandscen​icphotography.com (external link)
mickle
Joined Aug 2004
Feb 03, 2006 19:17 |  #2
A lot of people use a script I wrote for Photoshop CS & CS2
http://homepage.ntlwor​ld.com/pooternerds/Fra​mer/index.html (external link)
https://photography-on-the.net …&highlight=fram​ing+script
Mike
Visit Mikes Scripts & Actions (external link) for:
Photoshop framing scripts for CS & CS2 & CS3
Framing Script for Photoshop 7 & CS
Dynamic Velvia script for CS & CS2
Framer Action Set for PS7
Framer Action Set for PS Elements
Mikes Framer thread
xFilter
Feb 04, 2006 20:26 as a reply to  @ mickle's post |  #3
http://www.dl-c.com/Temp/ (external link) Mike's Framing Script is what I use but if you do not have PSCS2 check this framing software out.
Canon EOS Digital XT Silver
benf64
Feb 04, 2006 20:52 |  #4
i use FrameMaster http://www.galleriasof​tware.com/framemaster/​fminfo.htm (external link)
Ben
40d Extender EF 1.4x II,100-400 USM IS L, Tamaron 17-50 /2.8 EF 100mm f/2.8 USM Macro, Feisol CT-3401n, Bogen 88RC2
Kata R-102, 580ex flash
SuzyView
Feb 04, 2006 21:07 |  #5
What do I do? Just download it and it gets pulled up?
dandan
Joined Jan 2005
Feb 04, 2006 21:47 |  #6
i make my own frames in photoshop.
30mm, 50mm, 85mm, and some zooms here and there.
All nikon :D
- www.dan-mcnair.com (external link) - Webdesign and Photography (external link)
EOS_JD
Feb 05, 2006 08:22 |  #7
I too make my own in photoshop. You can make them as simple or as complex as you like
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
cargo123
Feb 05, 2006 23:07 as a reply to  @ mickle's post |  #8
Will your software work with Photo Shop 7?
mickle
Joined Aug 2004
Feb 06, 2006 00:15 as a reply to  @ cargo123's post |  #9
Only CS & CS2 at the moment.
My Current Skype Status is:
IMAGE: http://mystatus.skype.com/smallclassic/mickleuk.png
IMAGE LINK: http://callto://mickle​uk  (external link)
Mike
Mikes Framer thread
EOS_JD
Feb 06, 2006 11:45 |  #10
You can easily create nice fames in PS7 too though.
All My Gear
gardenstate
Feb 06, 2006 15:06 as a reply to  @ EOS_JD's post |  #11
You can easily add frames and mattes to images using Corel Paint Shop Pro and Corel Photo Album. By purchasing the older versions PSP9 and PA5 from eBay -- you can save lots of money. Many users and PSP sites post additional frame templates.
RodBarker
Feb 06, 2006 15:38 |  #12
Frames using styles are real easy in PS, only takes 10 seconds and the amount of styles bundled gives you many looks .
Rod
cargo123
Feb 06, 2006 20:51 as a reply to  @ RodBarker's post |  #13
Rod
Any instructions/links how I can do it? Thanks Mike
RodBarker
Feb 06, 2006 22:12 |  #14
Open your image and use your rectangle tool to draw out a box to the inside dimension of your intended frame , then invert your selection ,, now copy paste ,, you should have the intended frame on its own layer above the original image , now just apply a style to it from your styles tab , the small arrow in the corner allows you to load a new set to choose from , just click on a new one when you want a new frame look .
You can also fine tune a style by looking in your layers pallet at the layer you applied the style to , double click on the small f in the corner to open the properties of the style which you can fully tweak .
Rod
1,650 views & 0 likes for this thread, 10 members have posted to it.
2534 guests, 94 members online
