gjl711 wrote in post #16556857
If you have dust on your sensor it shows up 100% of the time. In busy areas it is just harder to see. When the image gets uniform, it stands out clearly. But to see it all over, do the sensor dust test.
1. take a picture at a small aperture. f/22 or higher. Take it of a uniformly colored subject. A clear blue sky does well as does a blank word document on your screen.
2. When taking the picture make it as OOF as possible. If shooting the sky, focus to MFD. If shooting your monitor, focus to infinity. Also, move the lens as well to introduce as much motion blur as possible.
What you will get is an extremely OOF image of a uniformly lit area. Only the dust specks sitting on the sensor will be somewhat in focus. To further enhance the dust specks, importing the image in to PS and using something like "auto-levels" will make the specks pop right out.
Yes, it will show up anywhere if it is there, including bokeh, just to mess with ya!:p My 600D's sensor has been very clean generally, but just this weekend, I noticed some white spots in some dark early morning shots I took, and a couple that looked big and dark as the sun rose. Didn't know where it came from, then realized it was because I had my rig on my cloth car seat. When I went to change lenses in the car to avoid drizzle or mist, I had moved my bag around and other things stiring up dust, so even in that short time with the body open, some dust fell into it and landed on the sensor. If I'd switched it off knowing it was there, it probably would have self cleaned, but with the moist air, it stuck, and leaving the camera on for pretty much the whole shoot, the spots showed up on everything, so had to do quite a bit of pp cleanup.
I got lucky, and was able to remove the dust with just a Rocket Blower later in the day.
if it's stubborn enough to not come off, I'd recommend a wet clean, but as mentioned, make sure you're comfortable doing so. do some research, and yes YouTube can be a great source of info with the better pro channels. It's not hard to do, but you've got to be physically comfortable (ie good workspace), interuption free, with good light, and most imprtantly...Have a reliable, and fully charged battery when locking up the mirror. This is the number one mistake people make when cleaning their sensors. The camera will also give out warning beeps if a battery is low or failing, so heed the warnings of the camera, and remove the swab immediately, and get the battery issue addressed. Your main risk is the mirror coming down, and (a. damaging the mirror mech., and/or (b. maring the sensor surface. The swabs themselves are very soft, and will not scratch, but the stick or handle end the cleaning material is attached to can poke through hitting the sensor if the mirror comes down on it.
Not saying this to scare you....Just things to keep in mind when doing it yourself. Again, it's pretty simple, and you will save yourself some time and money learning how.
Good luck!
