Thread started 26 Dec 2013 (Thursday) 20:17
First shots with these triggers, help :)
xarik
Joined Sep 2013
Dec 26, 2013 20:17 |  #1
Hey guys, I took this photo with some triggers that I got for Christmas and some CHEAP flashes I bought earlier this year
The flashes are Neewer TT520 speedlites, Yongnuo RF-603C triggers, canon t3i, canon 28-70mm F2.8 and a home made backdrop.
I am wondering how I should position my lights (2) in order to get a nice fill light on the face and prevent massive shadows?
I'm also wondering if anyone has the Yongnuo RF-603C triggers and if they like them/know if they will last?
IMAGE: http://i41.tinypic.com/8x8qh2.jpg
Thanks!
Bodies: Canon 5D3 - Canon 1D4
Lenses: Sigma 120-300mm F2.8 DG OS HSM SPORTS - Canon 100mm F2.8 L - Canon 70-200mm F2.8 L - - Canon 85mm F1.2 L V2 - Canon 40mm F2.8 Pancake
Extras: 2 Neewer TT520 Speedlites - Manfrotto 3021BPRO and ballhead
Check out my Flickr (external link)!
hbomb69
Dec 27, 2013 05:19 |  #2
you need to do lots of reading on portrait Lighting....its not something you can be told to do in one post on a forum....quick pointers to improve what you have already.
1. move further away from the background so the shadow has time to disperse
2. position your main light above your eye level (not Below) so the shadows fall downward, classic positioning is 45deg to the side and 45deg upwards.
3. Turn your face towards the direction of the light instead of away from it
4. your main and fill ratios don't look too far off, roughly have your fill light 1 stop below your main.
5. use a large modifier for your lights, eg shoot thru umbrella, this will soften the light and reduce the harshness of your shadows.
6. do lots of reading of portraiture!!!!!
The rf603 triggers are fine, they are durable and reliable.
Good Luck
Mike:d
CANON 5D MKIII x 2 / CANON 50D / CANON 550D
http://www.michaelhard​castle.co.uk (external link)
Facebook.com/michaelha​rdcastlephotography
JVthePT
Gallery: 130 photos
Joined May 2012
Dec 27, 2013 05:52 |  #3
Portraiture is brand new to me as is flash photography, and I'm learning as I go. Some days after reading an hour's worth of material I feel as though I just "unlearned" everything I had read up to that point!
I got tossed into taking our kid's portraits before we left for Christmas with my family and I didn't have a backdrop so I used a gray wall but the space was very close, literally about 8ft. Pulled an ottoman over and put it 2' in front of the wall, placed my YN560 on the floor behind the ottoman pointed up and set to 2/3 power and used the optical slave function. I got on the floor in front of the kids and put my 430EXII on camera and pulled out the little diffuser. The back flash kept shadows off the wall and washed out the gray wall. I was pleased with the result given the lack of planning or preparation that went into it. You can see the results on my flickr page. Don't want to post here and hack your thread.
6D & 7D mark II - Canon 16-35 f/4 IS L, Canon 24-70 f/2.8 L, Canon 24-105 f/4 L IS, Canon 70-200 f/2.8 IS II L, Canon 100-400 f/4.5-5.6 L IS II, Canon 50mm f/1.8 STM, Canon 85 f/1.8, Canon 100 f/2.8 USM macro, Canon EF 1.4x III
toolman21
Joined Jul 2011
Dec 27, 2013 11:21 |  #4
Read through this guys site, it is full of good information.
http://strobist.blogsp​ot.com/2006/03/lightin​g-101.html (external link)
The 603 have a good reputation so I wouldn't worry about those. You will need some stands and modifiers for the lights. Umbrellas are generally the cheapest option to start out with. If you are willing to wait you can get them really cheap on eBay ~$4 shipped maybe, a cheap hotshoe umbrella bracket ~$5 shipped and some cheap light stands ~$24 shipped for two. This won't be high end stuff, but it will be a start. It is generally the Cowboy Studio brand or similar. I have had a similar setup for almost 2 years and it is going strong as long as you aren't rough on your gear.
Now if you think you will stay into the hobby or can spring for better stuff there are lots of options of course.
I would probably start with just one flash and work from there. Add a cheap reflector, it can be one of the foldable ones or just a sheet of foamcore board from the dollar tree for $1 or WalFart carries some for ~$3 a sheet but they make great reflectors and cheap to boot.
The biggest thing you can do of course as hbomb69 said is just study portraiture and lighting.
This was shot with the cheap stand/umbrella/etc I mentioned above. Two bare super cheap slave flash things similar to these http://www.amazon.com …=8-3&keywords=slave+flash (external link) on stands either side of the rear and brolly type umbrella http://www.amazon.com …keywords=umbrel​la+softbox (external link) with a YN460ii flash on stand camera left overhead 45 degrees down. It could use some tweaking, but just an example that you can get decent results with cheap gear.
IMAGE: http://farm3.staticflickr.com/2820/11555381116_158afb9f60_c.jpg
IMAGE LINK: http://www.flickr.com …isiondigital/11​555381116/  (external link)
Can I get you any more egg nog? (external link) by EnvisionDigital (external link), on Flickr
Toolman21 - Canon 60d & T1i (sold) - Canon 17-55 | Canon 17-85 | Canon 50mm 1.4 | Sigma 10-20 | Canon 55-250
My Flicker (external link) | Like me on Facebook to follow my He-Man 365 nonsense (external link)| www.heman365.com (external link)https://www.facebook.c​om …n-Digital/34796106523515​2 (external link)
toolman21
Joined Jul 2011
Dec 27, 2013 11:30 as a reply to  @ JVthePT's post |  #5
This might help as well. I was 2ft or so from the tree.
nes_matt
Dec 27, 2013 20:57 |  #6
get your flash up off the floor. It should be higher than your head generally (it's a good starting point anyhow). 603 triggers are great, just keep some fresh batteries on hand for when you leave them turned on when you put them away... (or is that just me?)
Anything that looks lit on my flickr stream or FB (below) is done with 603's and cheap yn flashes.
Canon 6D & Rebel T1i | Tokina 11-16 F2.8 | Sigma 18-50mm F2.8 EX DC Macro | Nifty-Fifty |85mm f1.8 | Canon 24-105 F4 | Sigma 70-200mm f/2.8 EX DG OS HSM
Flickr photo stream (external link)
Portfolio (external link)
Facebook Page (external link)
nes_matt
Dec 27, 2013 20:59 |  #7
btw, definitely go through the strobist lighting 101. It will save you a ton of time and aggravation.
xarik
Joined Sep 2013
Dec 29, 2013 19:39 |  #8
OK I haven't taken the time to sit down and read comments much yet but I read a few
Here's some more that I took today because I had time and my GF wanted to model and I told her to take my picture ;P. I'll finish reading comments after editing this set
IMAGE: http://i40.tinypic.com/213pw6p.jpg
xarik
Joined Sep 2013
Dec 29, 2013 21:47 |  #9
I got some good advice from friends as well to add some umbrellas or something to bounce/shoot through. Apparently the lighting in the one above is too harsh. Toolman21, that's a nice image ;) Kreepy with the description lol!
I figured adding some bounces or umbrellas wouldn't cost too much more, I'm hoping I can utilize a spare tripod I'm receiving soon for a stand? Is that possible?
The more I shoot, the better I will get, but for now I have a few hours of reading to go ;)
xarik
Joined Sep 2013
Dec 29, 2013 21:49 |  #10
btw that image is not cropped, my GF just isn't very good at framing ;) lol she doesn't shoot, I just set up the camera and told her to take my picture
toolman21
Joined Jul 2011
Dec 30, 2013 12:15 |  #11
xarik wrote in post #16563137 (external link)
From the the holiday Classic National Lampoons Christmas Vacation, I suppose it makes more sense knowing that.
You can use a tripod to hold lights but they most likely won't be tall enough for most people standing. Sitting people you might get away with. You will have to get something to adapt down to a thread mount bottom as well, my triggers have a threaded hole on the bottom not sure about the 603. Then you still need a way to mount the umbrella to it. If you have no threaded hole most likely it will be cheaper and more practical as well to just get a light stand and bracket for the umbrella.
xarik
Joined Sep 2013
Dec 30, 2013 19:07 |  #12
What I was thinking was that I have one tripod that can go up 72 inches, that one will hold my slave flash (the flashes came with shoes that are threaded for a tripod). My second flash will be the secondary flash (for the right side or w/e) and will be holding the trigger (which sits between the foot and the flash so I can mount that as well) as for getting an umbrella on there...yeh I might just want to spend the $40 for a set of those and some umbrellas :P
xarik
Joined Sep 2013
Dec 30, 2013 19:55 |  #13
Adding this to my list of small purchases might make me a happy camper? :)
http://www.amazon.com …o+Compact+Umbre​lla+Swivel (external link)
toolman21
Joined Jul 2011
Dec 31, 2013 18:11 |  #14
If you have a 6ft tripod you can make it work as long as you have room to point down at an angle (aka short people) otherwise they will need to be sitting. I suppose you could put the tripod on a chair or something.
In any case the bracket you linked looks ok but I have never used them. These are the ones that I got initially. Super cheap but functional, that being said I am looking at the Manfrotto now as an upgrade for at least one of my sets because I want one that is threaded and not just hotshoe.
http://www.amazon.com …keywords=umbrel​la+bracket (external link)
Here is a kit that has 2 stands, 2 brackets, 2 shoot through umbrellas, 1 gold and 1 silver with carrying case for $45. Essentially the same stuff as I was talking about just packaged as a group.
The standard disclaimer: You will want to upgrade later so I would only get this stuff if you are broke or not sure if you want to continue or not. That being said at $45 it is almost disposable once you use it for awhile.
xarik
Joined Sep 2013
Dec 31, 2013 18:40 |  #15
I will have to wait a bit on getting that kit. Yes I am broke at the moment ;P Just bought a car that needs to be fixed up and I just spend $150 on a tripod and head as well ;P. Once I sell my XS and my spare Crapbook pro (macbook) I will have some spare money on hand for something like this. I'm too cheap to drop the cash atm lol....that's why I was just going to try and jerry rig it for a bit...idk if I will even use it later too
3,063 views & 0 likes for this thread
Latest registered member is karozenix
1054 guests, 310 members online
