Thread started 28 Dec 2013 (Saturday) 14:17
Searching for a low-distortion 18mm to 24mm fixed focus lens
plumgoo
Dec 28, 2013 14:17 |  #1
Does anyone have any suggestions (and possibly sample shots) for a Prime (fixed focus) lens in the 18mm to 24mm range. I already have a zoom (17-40 L) that covers the entire focal range, but I am especially looking for something with a LOT less barrel distortion. I shot horizontal subjects (windows and doors: see my gallery in my signature for what I mean), and the barreling really shows in most of my shots. I know how to reduce the effects through distance, height, zooming out as wide as possible and then cropping, or zoom in as tight as possible, etc. But what I am looking for is a nice CANON lens, of which there are only a few in mind, but does anyone have any experience with fine horizontal lines and focal lenghts in this range?
Thanks in advance.
60D | Canon 70-200L 4.0 | Canon 17-40L 4.0 | Canon 60 2.8 | Canon 85 1.8 | Sigma 30 1.4| Tokina Fisheye 10-17 3.5-4.5 | Walimax Pro 500 | Tamron 1.4x | Various other bits |
My Smugmug (external link)
xarqi
Dec 28, 2013 16:37 |  #2
The 24L II is said to be pretty decent in terms of barrel distortion, especially on APS-C, but I've no personal experience with it.
Nick3434
Gallery: 33 photos
Dec 28, 2013 17:00 |  #3
The 24 handles distortion really well. Like, I don't even bother correcting it. If you look at my flikr, anything wide and recent is with that and I have not corrected distortion once since I got it.
When I finally use it inside for interiors I am sure I will need correction, but outside heavy architecture what is present is very subdued.
Everything is relative.
Gear: 6D, Unholy Trinity:twisted: (24Lii, sigma 50A, 135L), and for the other ends of the spectrum, sigmaEX 14mm2.8 and sigmaEX 100-300F4.
Fuji X-e2, Rokinon 8 2.8 Fisheye II, Fuji 14 2.8, Fuji 18-55, Fuji 23 1.4
FlikR (external link)
lilkngster
Dec 28, 2013 17:25 |  #4
24mm TSE if you do not want to go the software route, i.e. Adobe and DxO.
6dII/1dIII|Bronica Sq-Ai/EOS 3/A1
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Dec 28, 2013 17:32 |  #5
^^+1 It sounds like you are looking for a tilt shift lens, which is designed for exactly what you've described. Canon makes a 24mm and 17mm, and Samyang makes a pretty well regarded 24mm, as well.
artyH
Dec 28, 2013 17:35 |  #6
The 17-40 will do OK in therms of distortion at 24 mm on crop. Have you checked this out? It will give some distortion at 17, but levels will be lower at 24 mm.
plumgoo
Dec 29, 2013 03:32 |  #7
Yep, I've set my 17-40 to 24mm, but there still is some barreling, not much, but it's still noticable with the type of photos I tend to shoot.
As for a tilt-shift, thought it would definitely be something that would cure all of my barreling problems (and be awesome to have),that's probably not something I would get due to the cost. I'm not sure I want to spend 2,500 dollars (US) on a lens, a thousand, yeah, but 2.5 times that amount, ehh... nope. :)
I have seen that lightroom5 has a distortion correction function, sooo... I might check that out too, but I still wouldn't mind picking up a nice prime in that focal length specifically for architecture.
Thanks for the replies!
Mornnb
Gallery: 6 photos
Joined Aug 2012
Dec 29, 2013 04:53 |  #8
Try the Tokina 16-28mm. It has almost no distortion at 24mm and is a lot cheaper than the 24L.
See http://www.photozone.d​e …tokina162828eos​ff?start=1 (external link)
Canon 5D Mark III - Leica M240
EF 16-35mm F/4 IS L - EF 14mm f/2.8 L II - - EF 17mm TS-E L - EF 24-70mm f/2.8 L II - EF 70-200mm IS II f/2.8 L - Sigma 35mm f/1.4 Art - Sigma 85mm f/1.4 EX
Voigtlander 15mm III - 28mm Elmarit-M ASPH - 35mm f/1.4 Summilux-M FLE - 50mm f/1.4 Summilux-M ASPH
500px (external link)
kdrk888
Dec 29, 2013 05:44 |  #9
I have a 16-35 which I don't use much. I don't like to carry it around in my bag which I may not use it at all during the outings. Wish Canon would make a good 16mm or 17mm prime with IS. Please don't tell me IS is useless on a UW. I want to be able to shoot at low ISO and at slow speed with decent DOF when tripod is not an option.
Douglas
Canon, Nikon, Sony. Too many gears, too little time.
troutfisher
Gallery: 23 photos
Dec 29, 2013 05:48 |  #10
Either a TS-E , 17 or 24mm or try DxO optics if you want to try the software route
Chris
" Age and treachery will always defeat youth and enthusiasm"
speedync
Gallery: 291 photos
Joined May 2011
Dec 29, 2013 06:59 |  #11
Canon EF 24mm f/2.8 IS USM? http://lenstests.com …f-24mm-f2.8-is-usm-page-2 (external link) http://www.lenstip.com ….8_IS_USM_Disto​rtion.html (external link)
Shane ­ W
Dec 29, 2013 08:38 |  #12
Am I missing something here? Isn't this distortion pretty easy to correct in post? I really like UWA shots and use my Sig 10-20 often and find it only takes a moment to fix the barrel effect in Lightroom.
Shane W
70D | Sig 10-20 | EF-S 15-85 | EF 70-200 2.8L | Sig 150-500 | Viv 28 2.5 | Sig 30 | Tak 50 1.4 [COLOR=blue]| EF 100 2.8 Macro | 1.4x TC | Nodal Ninja 3 | Tripods | Some Flashes | My flickr  (external link)
Snydremark
Gallery: 66 photos
Dec 29, 2013 10:16 |  #13
plumgoo wrote in post #16561157 (external link)
That was why I mentioned the Samyang; it can be had for around 8-900 USD, and it's reviewed quite highly compared with the Canon version
Cesium
Dec 29, 2013 14:35 |  #14
The Canon EF-S 10-22 seems to do pretty well in distortion tests in that range. Doesn't quite get you to 24mm, but close enough.
Click around here:
http://www.the-digital-picture.com …&CameraComp=453​&FLIComp=0 (external link)
BTW, I enjoyed clicking around your smugmug, especially the "people of vienna" section.
ejenner
Gallery: 98 photos
Joined Nov 2011
Dec 29, 2013 14:38 |  #15
Shane W wrote in post #16561423 (external link)
It is, and is what I do, but it does have an impact on sharpness.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
2,737 views & 0 likes for this thread, 13 members have posted to it.
1349 guests, 130 members online
