Thread started 04 Feb 2006 (Saturday) 00:15
Made my own ring flash...check it out
shakin360
Feb 04, 2006 00:15 |  #1
I saw one of those chip trays with the built in bowl in the center at the dollar store and though "hey, i bet I could make a ring flash with that". I cut out part of the center and a hole for the flash. Lined the whole inside with foil and covered it with a sheer material. 20 bucks and a few hours later (Plus 70 bucks for the off camera cord. I know I could get it for 50 at B&H, but I was really impatient and wanted to see if this thing worked. I just went to a local store to get ripped off.) Here it is. I have a feeling that is is a little small, probably should have a bigger diameter. Anybody know what setting I should have my flash set at for this thing. I plan on painting the bracket black and intalling a grip to make it more comfortable. Also, maybe a way to mount it on a tripod. The camera can be adjusted forwards or back, so I can us it with different lenses. Hopefully I'll get a chance to try it out this weekend.
IMAGE: http://i10.photobucket.com/albums/a137/actke/100_4619.jpg
IMAGE: http://i10.photobucket.com/albums/a137/actke/100_4621.jpg
IMAGE: http://i10.photobucket.com/albums/a137/actke/100_4622.jpg
www.myspace.com/aophot​ography (external link)
http://www.modelmayhem​.com/member.php?id=121​511 (external link)http://www.modelmayhem​.com/aophoto (external link)
www.photokenosha.com (external link)
bolantej
Feb 04, 2006 01:24 |  #2
not a bad job. any shots yet?
shakin360
Feb 04, 2006 01:49 |  #3
hopefully tomorrow!
It is a little ugly, didn't know what do do with the excess diffuser material, I should have used velcro I guess.
Lotto
Feb 04, 2006 06:02 as a reply to  @ shakin360's post |  #4
Great job on the DIY project, bet it would look sweet once it's finished. Love the way you make the brackects to secure everything together.
Try the automatic ETTL mode first, use FEC if needed. For mounting on tripod, is there any room left at the end the bottom of lever behind the 580 mounting poit? Could tap a 1/4 20 thread on it and you will be all set.
I too want to see the test shots. Could you include a picture of ring flash itself when firing?
5D, 24-105L, 70-200L IS, 85mm Art, Godox
TeeJay
Joined Jun 2005
Feb 04, 2006 06:30 |  #5
Ingenius device! I like the bracket, but have you got room to use the zoom on the lens? - and where does your chin fit in? :-)
1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea :confused:
shakin360
Feb 04, 2006 11:22 as a reply to  @ Lotto's post |  #6
I did leave some room for a tripod mound at the bottom. :)
I took some shot in a mirror. I'll post them a little later.
shakin360
Feb 04, 2006 11:25 as a reply to  @ TeeJay's post |  #7
I do have room for my room, and there should be room to use a few different lenses, as long as they aren't too long. I looks like the bracket would get in the way of your chin, but surprisingly it doesn't. I have a realy big head and it doesn't even touch my face.
Michael ­ L
Joined Jun 2005
Feb 04, 2006 13:01 |  #8
I cant wait to see some shots from it. You should apply for a Patent on your prototype if it works better than other devices desgined to make a flash less harsh. I dont think there are any other devices that go all the way around the lens like yours does?
shakin360
Feb 04, 2006 15:04 |  #9
There are companies that make real ones. Look here. http://www.bhphotovide​o.com …flash&image.x=0​&image.y=0 (external link)
They are a little pricey though. I have seen a couple other DIY projects like this one on the net. This one is similar to the "planter style" ring light.
shakin360
Feb 04, 2006 15:11 |  #10
Here is a pic I took in a mirror about 15-20 ft away. The pic isn't very good, but you can see the flash going off. Because it is quite small, I think it would be good for headshots, but maybe not full body. I won't know though until I actualy try it on someone. Thanks
IMAGE: http://i10.photobucket.com/albums/a137/actke/Picture151.jpg
Lotto
Feb 04, 2006 15:42 as a reply to  @ shakin360's post |  #11
Thanks for the test pic. The light looks like is evenly distributed inside the ring.
Once it's mounted on a tripod, the camera could be removed and now you have a small softbox too. Ingenius device indeed.
weverb
Feb 04, 2006 16:09 as a reply to  @ Lotto's post |  #12
Love this idea. Thanks for sharing with us. I will never look at a chip tray the same again!
mbze430
Feb 04, 2006 18:01 |  #13
let me know if you get a hot spot near the flash head area.
My Hub to my personal work (external link) (just click on the banners)
BearLeeAlive
All butt cheeks and string.
Feb 04, 2006 18:17 |  #14
C'mon, c'mon you have me eager to see the results of this fancy new device. Looks like a great idea.
-JIM-
md_129
Joined Nov 2005
Feb 04, 2006 18:35 |  #15
wow, great concept.
Mike
Current Projects:
http://webdoctus.com/ (external link)
6,505 views & 0 likes for this thread, 18 members have posted to it.
1190 guests, 122 members online
