Hi all,
I would like to explore the reverse lens macro technique. In the setup with two lenses (a zoom lens normally mounted + a reverted prime lens), the reverted lens shuold have a manual aperture ring. I guess is not so easy to find such lens. In some second hand website I found the Canon FD 50mm 1.4 (and 1.8). Do you know if these two lenses have a manual aperture ring ? And if they are appropriate for reverse macro ? Other suggestions on which lens combination to use ? Thanks
