Thread started 02 Jan 2014 (Thursday) 03:20
samyang 35mm f1.4 infinity issue
simpy
Joined Mar 2012
Jan 02, 2014 03:20 |  #1
Hi,
I have just bought my lens second hand. Tested manual focusing at various distances at 1.4, all are ok, except for when I set it to infinity, and want to focus something really far away, non of the distance objects are in focus.
Is this what everyone else is getting as well?
I just want to know if I have a bad copy or not.
On my other lenses,I can turn it max on infinity and it always keep the distant objects in focus.
Cheers
Canon 5dm2
kent ­ andersen
Jan 02, 2014 09:54 |  #2
I have the same problem.... and it came afther I droped the lens on the floor. Around 20-30 cm.
The glass on the lens is excelent, but the build quality is less excelent. You need to handle the lens with extreme caution. It can probably be adjusted, but Samyang is not famous for suport. If you still have guaranti on it, take contact with their support. If you are lucky they send you a new one.
I had the same Problem with a 135L, and after adjustment it was all ok.
Living in Austria, I am so glad that there is stuff like Gimp out there...
I am a happy giver, so if you find any misspelling in my text, you can keep them... :)
Flickr: http://www.flickr.com/​photos/41388512@N05/ (external link)
ean10775
Jan 05, 2014 19:03 |  #3
The infinity focus marking on my copy if the lens could not be relied on. I'm used to this from using many adapted legacy lenses on my 5DII. I don't know whether this is the norm for this lens, but my copy was purchased brand new and had never been dropped.
My Flickr (external link)
MalVeauX
"Looks rough and well used"
Gallery: 1696 photos
Joined Feb 2013
Jan 05, 2014 19:47 |  #4
simpy wrote in post #16570988 (external link)
Hi,
On my other lenses,I can turn it max on infinity and it should always keep the distance objects in focus.
Cheers
Heya,
Lots of lenses at their "infinity" setting are not at infinity, they're beyond infinity. Look for the line that comes near infinity, and that's your infinity mark. Otherwise, look through the view finder, manual focus it to infinity or hyperfocal it, and mark it. That's infinity.
Very best,
Daniel0663
Joined Nov 2013
Jan 05, 2014 20:17 |  #5
I had the same problem with my Samyang 35mm (New). So i ended up taping the focus distance markings and made my own distance scales with a sharpie marker. It only took 10-20mins of my time but it was well worth it.
5D|Primes
simpy
Joined Mar 2012
Jan 05, 2014 22:10 |  #6
my issue isn't really the focus distance scales, I manually focus, but my focus doesn't actually 'reach' infinity, so it restricts me from focusing distant objects, such as a full shot of a car. so pretty much doesn't focus further than 3metres
Canon 5dm2
uOpt
Jan 05, 2014 22:14 |  #7
simpy wrote in post #16581154 (external link)
That sounds broken, as in too much distance between camera and lens.
My imagine composition sucks. I need a heavier lens.
ZoneV
Jan 06, 2014 03:44 |  #8
Big tolerances in register distance or internal focus setting are quite normal for Samyang lenses. But it is rare that infinity setting is no longer possible.
Probably you could adjust the internal focussing under the focus ring. Most likely it is hard to shorten register distance (without lathe).
DIY-Homepage (external link) - Image Gallery (external link) - Gear List
paparios
Jan 06, 2014 06:54 |  #9
Hi,
Cheers
These manual lenses are best used through liveview. Those of us, who used old film cameras, we are accostumed to use manual focussing through the viewfinder, by turning the focus ring up and down a few times until we consider the right place.
Miguel
Canon 5D MKII, Sony A7, Canon EOS M, Canon 7D, Sony A6000, Canon 50d with grip, Canon 400D with grip, Bower 14 f2.8, Bower 35 f1.4, EF 40 f2.8, Tokina 12-24 f4, EFM-22 f2 STM, EFM 18-55 f3.5-5.6 IS STM, EFS 18-55 f3.5-5.6, Tamron 28-75 f2.8, EF 85 f1.8, EF 100 f2.8L IS, EF 70-200 f4L IS, EF 75-300 f4-5.6, Sigma 150-500 f5-6.3, Sony E 16-50, Sony FE 28-70
ZoneV
Jan 06, 2014 07:19 |  #10
paparios wrote in post #16581723 (external link)
These manual lenses are best used through liveview. ..
But this doe not help much when infinity is not possible due to mechanical restriction somehwere.
I love to have accurate distance scales - helps sometimes in very very dark enviroments or when I can not use the viewfinder (have no liveview with tiltable display).
simpy
Joined Mar 2012
Jan 08, 2014 00:37 |  #11
ZoneV wrote in post #16581763 (external link)
Correct here,
I have tried to claim warranty but they refuse to fix it. The company I'm dealing with is horrible,
Does anyone know if there's any possible DIY fix?
If not, looks like it will have to be a close up lens unfortunately ...
Canon 5dm2
ZoneV
Jan 08, 2014 01:08 |  #12
simpy wrote in post #16587306 (external link)
I suppose it should be the same like with their 14mm lens
http://www.flickr.com …iscuss/72157632​529862778/ (external link)
http://forum.mflenses.​com …amyang-35-1-4-t47857.html (external link)
simpy
Joined Mar 2012
Jan 21, 2014 04:31 |  #13
this is more of adjusting the scale,
my lens does not reach infinity at all..
Canon 5dm2
Jerobean
Jan 21, 2014 10:13 as a reply to  @ simpy's post |  #14
Classic Sigma focus issues.
6d, 24-105L, Tak SMC 50 1.4, 85 1.8, 135L
rparchen
Jan 21, 2014 10:40 |  #15
Jerobean wrote in post #16623861 (external link)
You may want to re-read the thread
simpy wrote in post #16623216 (external link)
That's a bit strange. My old 14mm would focus past infinity, hence the fix in the video which I did, but my previous Samyang 35mm would pretty much stop right at infinity. Is it possible that something is inside which is preventing it from focusing? I don't think it would take much but I'm not sure how to disassemble the lens to check.
Rick - Sony A7R (RIP 6D), Samyang 14, Zeiss 21/35/50, Canon 70-200L
Facebook page for updates (external link)
www.parchenphotography​.com (external link)
IG: @ParchenPhotography
4,381 views & 0 likes for this thread
Latest registered member is armychemical
1031 guests, 294 members online
