Thread started 02 Jan 2014 (Thursday) 19:50
Upgrade to Windows 7
mayt444
Joined Feb 2004
Jan 02, 2014 19:50 |  #1
Good day all. I am running CS3 and DPP on my Windows XP pro computer. I recently upgraded to the 70D and can no longer use camera raw to process photos. I can still use DPP but kind of miss camera raw. I have looked into getting CS6 or Lightroom 5 to process images but system requirements for both call for Windows 7. One thing system requirements doesn't say is if it has to be 64 bit or 32. I have avoided upgrading to 7 but it looks like it is inevitable unless I can find another solution. I know one advantage to 64 bit would be running more memory. Any thoughts on the subject? Like maybe the cheapest easiest route?
Clay
Clay
Canon 70D, Canon G12 , Tamron SP 150-600mm Di VC USD, Sigma 17-70mm F2.8-4 DC Macro OS HSM C, Canon 18-55 IS STM, 55-250 IS, Canon 50mm 1.8 II.
mike_d
Jan 02, 2014 19:59 |  #2
How old is your computer and what are the important specs? Anything still running XP is likely too old to bother sinking any more money into.
If you do upgrade, buy an OEM copy of Win7 from Newegg or Amazon and do a clean install. 64 bit is the default today because almost everything sold now has at least 4GB of RAM. A 32 bit OS will only see up to about 3.3GB of RAM, less if your video card has lots of memory. 32bit applications running on a 64 bit OS will have access to less RAM than if you ran the 64 bit version.
Ray ­ Marrero
Gallery: 23 photos
Jan 02, 2014 20:06 |  #3
What are you waiting for? And skip Win7. Go straight to Windows 8.
Ray
Canon 6D, 7D, 30D, Flashpoint Zoom Li-on R2 x2, Flashpoint eVOLV 200 and XPlor 600, AB800 x3, Canon 10-22mm, 18-55mm, 50mm 1.8, 85mm 1.8, 24-70mm 2.8L, 24-105mm 4.0L, 70-200mm 2.8L IS, Sigma 28-105mm 2.8, Tamron 28-75mm 2.8, CyberSyncs.
mike_d
Jan 02, 2014 20:13 |  #4
Ray Marrero wrote in post #16573057 (external link)
Do you think anyone who's been avoiding Win7 (arguably the best version of Windows ever) for 4+ years wants to move to the clusterf**k known as Win8?
mayt444
Joined Feb 2004
Jan 02, 2014 20:14 as a reply to  @ Ray Marrero's post |  #5
I built the computer 2 years ago. LIAN LI Lancool PC-K7B Black Aluminum/ SECC ATX Mid Tower Computer Case, ASUS M4A88T-V EVO/USB3 AM3 AMD 880G HDMI USB 3.0 ATX AMD Motherboard, AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor, G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM, OCZ ModXStream Pro 700W Modular High Performance Power Supply. The motherboard supports up to 16gb memory. So just bite the bullet and get 7?
Clay
digirebelva
Gallery: 376 photos
Jan 02, 2014 20:31 as a reply to  @ mayt444's post |  #6
Yes...
BamPhoto
Jan 02, 2014 20:32 |  #7
Upgrade win 7 is a good os imho, you will need it to go to Lightroom 5 or cs6 or cc also.
Randy
My Gear List and Feedback
Website (external link)
mayt444
Joined Feb 2004
Jan 02, 2014 20:50 as a reply to  @ BamPhoto's post |  #8
Thanks for the support. I am thinking of going to Lightroom 5.
Clay
emvy
Joined Nov 2013
Jan 02, 2014 21:06 |  #9
You will not be disappointed by Windows 7, your config is perfectly suited for it, I would wedge in another 4GB of RAM and you'll be set. Snap your neck before thinking about Windows 8 though.
mike_d
Jan 02, 2014 22:01 |  #10
emvy wrote in post #16573217 (external link)
Yep. This.
Potisdad
Jan 03, 2014 00:03 as a reply to  @ mike_d's post |  #11
Hi Clay,
I just made a similar upgrade from Vista to Win 7 64, to get LR5, and can thoroughly recommend you make the jump.
I am a computer novice and the easy way is to add a SSD and install Win 7 on that, then a quick tweak of the boot drive order in BIOS and you are away. If it doesn't work just unplug the SSD and you can boot up in XP again. Good time to plug in more RAM too - cheap and easy.
I used Windows Easy Transfer to move some stuff and Win 7 Library makes it easy to still access files on the old drives.
David
YP5 ­ Toronto
Jan 03, 2014 11:23 |  #12
If you are going to move to a new OS....just go to 8.1
8.1 address some of the concerns people had in 8.0
Canon 7D Gripped |Tokina 11-16 | Sigma 30mm F1.4 |Canon EF 24-70L | |Canon EF 70-200L F2.8IS MKI |Sigma 530DG | Giottos 9360 | Giottos MH-1301 | Giottos MH656 | Spyder2Pro | Kata 3IN1-20 | Kata Bumblebee UL-222
mike_d
Jan 03, 2014 11:40 |  #13
YP5 Toronto wrote in post #16574472 (external link)
8.1 doesn't address any of my problems with it. All it does is tweak metro a bit, add a button to take you to tablet-land (thanks, Microsoft :rolleyes:), and become even more insistent that you logon with a Microsoft account.
Win8.x is still a touch screen tablet OS forced into a place it doesn't belong.
YP5 ­ Toronto
Jan 03, 2014 11:42 |  #14
Ah well.. can't please everyone.
Bob_A
Gallery: 48 photos
Joined Jan 2005
Jan 03, 2014 11:48 |  #15
mike_d wrote in post #16574521 (external link)
Anyone that has built their own computer (such as the OP) has enough skill to configure Win 8.1 such that 1) you never have to see Metro, 2) you never need to logon with an MS account and 3) for $3 you can have an exact replica of the Win 7 start button (StartIsBack+) ... and you end up with a better OS than Win 7. Win 8.1 is the same as Win 7 with speed advantages and an improved Windows Explorer.
I used to think the same way as you, but after messing around with Win 8/8.1 for a few months I'd now only recommend Win 7 to someone that is technically challenged or to someone that really needs XP Virtual Machine.
Bob
3,465 views & 0 likes for this thread, 12 members have posted to it.
926 guests, 115 members online
