Thanks to the both of you for your help!
John from PA wrote in post #16577365
First of all post or link to a poor image that has the full EXIF information. That enables us to see virtually every setting of the camera and thus more likely avoid speculation as to cause.
I've formatted my SD card and it's now night time in France, I will post some examples tomorrow
amfoto1 wrote in post #16577393
It's been noted that the AF of the 50/1.8 is too erratic to reliably Micro Focus it. I've seen discussion of that various places. Reikan FoCal, which runs a series of focus tests to establish a useful amount of adjustment, gave up on the EF 50/1.8, because it was so erratic that any correction dialed in was meaningless.
But your other lenses should be "fine tunable".
The 6D's center AF point is the only cross-type in the array and is much better than the other 10 peripheral points. The center one is rated by Canon to -3EV, while the all the others are only rated to be able to focus down to +0.5EV. So be sure you are doing your testing in really good light. (For comparison, the 5D Mark III has 61 points, upt to 41 of which are cross-type, and is rated to -2EV with all of those).
I don't know why the MFA settings you are making aren't being retained. Are you losing other settings in the menu or custom functions? If so, I'd suspect the memory battery (which unfortunately isn't user replaceable).
I was aware of the type of sensors difference in 6D between the center point and the outer ones; but this is something I seem to be able to fix with MFA so I was thinking they were not getting the proper information. But well if I can get the center point working properly that would be great
I don't know if the settings are not retained, they are still displayed in the menu, but for a period of times all my pictures will be perfect with a +14 dialed, then for another period of time it will be perfect with a 0... Really strange!
There's also another strange thing, not matter the MFA setting I cannot manage to get the iris' sharp, but the eye lashes are razor sharp.
But I think it will be clearer with the pictures tomorrow! Thanks again for your help!
