Thread started 04 Jan 2014 (Saturday) 19:36
What did I do? 60D dead – HELP!
CRobH
Joined Dec 2011
Jan 04, 2014 19:36 |  #1
I accidently grabbed my 60D without a card in it and started to take photos. It took a few then froze up. I then realized that it didn’t have a memory card in it. Now the camera will not work. When turning on the red light blinks twice then nothing.
Any clues on how to get the camera working again????
I have tried removing and replacing battery. No luck...
TTuna ­ Eye
Joined May 2011
Jan 04, 2014 19:43 |  #2
Try a hard reboot. I think the process is to remove the battery, turn it on even without the battery, then hold the shutter button for 60 seconds, then turn the switch to off then reinsert the battery and try it. That may not be the exact process but you can search it. I don't think it is toast, you will get it back.
6D, 60D, 100L, 24-105L, Sig 150-500, nifty 50, EF-S 60mm, Tam SP70-200 f/2.8 Di VC, Underwater gear T2i in a Watershot housing with Inon S2000 strobes.
mak65
Jan 04, 2014 19:50 |  #3
I don't have a 60D so TTuna may be correct for this model but I thought a hard boot required removal of the main battery AND the small battery that runs the clock/date data. Leave both out for about 30 minutes and reinsert.
Hopefully this will do the trick. Good luck!
unistudent1962
Jan 04, 2014 20:02 |  #4
http://www.dpreview.co​m/forums/post/39591118 (external link)
Canon 70D w/Grip l Canon 60D w/Grip l EF 100-400 F4.5-5.6L IS l EF 70-200 f4L IS l EF-S 15-85 f3.5-5.6 IS USM l EF 100mm f2.8 USM Macro l EF-S 18-55mm f/3.5-5.6 IS STM l EF 50 f1.8 II l EF-S 10-22 f3.5-4.5 USM l 430 EX II Flash l Manfrotto 055XPROB + 498RC2 Tripod l Benro MP-96 M8 Monopod l Lowepro Vertex 200 AW Backpack l Lowepro Pro Runner 300 AW Backpack l PS CS5 Extended l Lightroom 4.3
John ­ from ­ PA
Joined May 2003
Jan 04, 2014 20:22 |  #5
I thought a hard boot required removal of the main battery AND the small battery that runs the clock/date data. Leave both out for about 30 minutes and reinsert.*
Don't look for a backup battery because there isn't any in the 60D. Remove main battery, turn on, hold shutter button down, turn off, reinsert battery. Make sure memory card is installed, then power up.
webejamn
Joined Jun 2005
Jan 04, 2014 21:00 as a reply to  @ John from PA's post |  #6
im curious why it would need a memory card, and why shooting with out a memory card would cause this, i can not imagine that the camera is that sensitive that it would "break" with out a memory card while shooting
im just asking because i dont think shooting with out a memory card is the issue.
http://www.imdb.com/na​me/nm0000188/ (external link)
Rashkh
Joined May 2011
Jan 04, 2014 21:07 |  #7
https://photography-on-the.net …/showthread.php​?t=1222229
I agree with what's stated in the linked thread. The 60D shoots without a card by default, likely for demo purposes. It's highly unlikely that lack of memory card is the reason your camera malfunctioned.
CRobH
Joined Dec 2011
Jan 04, 2014 21:20 |  #8
First of all I want to thank you all for responding.
Before I was going to dive into the suggestions above I wanted to make sure the battery had a full charge. It was low but I didn’t think it was low enough to cause the camera to just shut down.
After reading comments by “webejamn and Rashkh” I decided to put the partially charged battery back in the camera to see what would happen.
This is the EMBARRASSING part...... The camera fired right back up. It was a low battery……It was just a coincidence that it died when there was no memory card. I just assumed that was the reason that it froze.
Thanks again for all of the replies.
rrblint
Gallery: 84 photos
Joined May 2012
Jan 04, 2014 22:56 as a reply to  @ CRobH's post |  #9
I just love a happy ending.:D
Mark
jhayesvw
Gallery: 167 photos
Jan 04, 2014 23:08 |  #10
ha. Good outcome.
LIve and learn. No big deal.
Enjoy the 60d
My Flickr (external link)
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Jan 05, 2014 05:26 |  #11
CRobH wrote in post #16578241 (external link)
Post hoc ergo propter hoc.
We've all been caught out by silly things, glad it is sorted.
Dan Marchant
mainbyte
Joined Mar 2011
Jan 05, 2014 06:04 |  #12
John from PA wrote in post #16578106 (external link)
There is a backup battery in the 60D, but.... it is mounted internally on the circuit board. You would have to dismantle the camera to get at it.. yuck!
Ron
Canon 6D | Canon 7DII | 17-40 f/4L | 24-105 f/4L | 70-300 4/5.6L |100mm f/2.8L macro | 50mm 1.4 | 580exII | 2 - 430exII |
tzalman
Fatal attraction.
Jan 05, 2014 06:43 |  #13
Dan Marchant wrote in post #16578856 (external link)
Dan, that is for sure the most common human fallacy. In fact, there is a brand of beer that has a whole series of commercials based on it.
Elie / אלי
webejamn
Joined Jun 2005
Jan 05, 2014 21:47 as a reply to  @ tzalman's post |  #14
Thats great news, glad to hear it wasnt anything major. i usually start with human error as when beginning my troubleshooting, and it is usually the case.
3,702 views & 0 likes for this thread, 12 members have posted to it.
932 guests, 117 members online
