Thread started 05 Jan 2014 (Sunday) 09:30
Ideas on this PC for Photoshop CS6
Thorrulz
Gallery: 20 photos
Jan 05, 2014 09:30 |  #1
I'm thinking about this PC, LINK (external link) to replace my current photo editing rig. It seems to be what I need with a CUDA supported videocard that CS6 could take advantage of. Plus the 32gb of ram and i7 processor seem to make it a very capable photoediting machine.
I should add that if I get this or any other pc I will add a ssd drive for the photoshop application with another two 7200rpm drives for the images themselves when working.
Any thoughts or concerns anyone?
D800 I Nikon 200 f2 VR 1 I Nikon 200 f2 ED AI-S I Nikon 135 f2 DC I Nikon 28-70 f/2.8 I Nikon 50 f/1.4G I Nikon 85 f/1.8G I Pentax 645D I SMC FA 645 75 F2.8 I SMC FA 645 45-85 F4.5 I SMC FA 645 200 F4
My sister, the professional baker and cake decorator once told me that my camera takes great pics. My reply was that I thought her oven baked great cakes.:lol:
flickserve
Jan 05, 2014 12:48 |  #2
Looks great. Wish I had one...:)
DiMAn0684
Jan 05, 2014 13:16 as a reply to  @ flickserve's post |  #3
Was going to say that it would be nice to have an SSD at this price point, but sounds like you're planning on adding one anyways. Specs look good otherwise.
Canon 5D MkII | Canon 16-35mm f/4 | Canon 50mm f/1.8 STM | Canon 24-105mm f/4 | Tamron 70-300mm VC | Canon 430EX II | Benro A2682TB1
Geonerd
Jan 05, 2014 18:16 |  #4
AFAIK, the CUDA acceleration is limited to a few blur filters and will do nothing for 99% of your PS workflow. IMO, I'd hold off on a $$$ videocard until whatever software you use makes more comprehensive use of the GPU.
Thorrulz
Gallery: 20 photos
Jan 05, 2014 20:49 |  #5
Thanks to everyone that replied, I think I will probably order that pc I linked to and it should be overkill for my present needs at the very least. Geonerd, I understand that the videocard isn't as important or as needed by most of what I'm doing in photoshop but I also do some video editing so I think that software will benefit from it.
1000arms
Jan 05, 2014 21:31 |  #6
“Optimizing Hardware Systems for Adobe® Premiere® Pro CS6, After Effects® CS6, SpeedG
Thorrulz wrote in post #16579201 (external link)
The linked computer looks good. Getting a SSD (as you mentioned) for the boot drive is a good idea. For the video work (you mention in a later post), you might also use a SSD for a cache drive, in addition to the other drives you mentioned.
Take a look at the Adobe White Paper linked in the first thread of https://photography-on-the.net …/showthread.php​?t=1283184Optimizing Hardware Systems for Adobe® Premiere® Pro CS6, After Effects® CS6, SpeedGrade™ CS6, and Photoshop® Extended CS6"
tim
Light Bringer
Jan 05, 2014 22:00 |  #7
Video card is overkill, a 620 or similar is plenty, the 760 won't make things any faster. With an SSD that'll be a nice machine.
1000arms
Jan 05, 2014 22:10 |  #8
tim wrote in post #16581134 (external link)
Thorrulz wrote in post #16580947 (external link)
The OP has mentioned video work. Also, some of PS CS6 can make very good use of the right GPU. The Adobe White Paper (that I have linked to in a prior post) covers those features.
tim
Light Bringer
Jan 06, 2014 13:23 |  #9
Ah yes, video editing was only mentioned later, that could benefit from a good video card.
1000arms
Jan 06, 2014 13:45 |  #10
tim wrote in post #16582600 (external link)
There are some things in PS CS6 that can also make good use of a dedicated video card. I suggest you check the Adobe White Paper http://www.adobe.com …erformance-whitepaper.pdf (external link)
Geonerd
Jan 06, 2014 14:01 |  #11
1000arms wrote in post #16582658 (external link)
Adobe saying that a given function is CUDA accelerated is not the same as saying you will see meaningful benefits. Properly multithreaded x86 code, if present, (Hello, Adobe?) may well be just as fast.
Call me cynical, but until someone quotes reliable, real world, PS+CUDA benchmarks, I tend to view this paper as more of a marketing device than an actual spec sheet.
1000arms
Jan 06, 2014 16:32 |  #12
Geonerd wrote in post #16582709 (external link)
You may view it anyway you like. :)
I think that the Adobe White Paper, that I linked in a prior post, is too long to simply be a marketing device. I will mention that there are some times, without and with GPUs, for Adobe® Premiere® Pro CS6 and After Effects® CS6, in the Adobe White Paper.
I want to avoid hijacking this thread, so I will encourage you, and anyone else who would like to continue our discussion, to post on https://photography-on-the.net …/showthread.php​?t=1283184
2,313 views & 0 likes for this thread, 6 members have posted to it.
1136 guests, 169 members online
