Thread started 07 Jan 2014 (Tuesday) 17:28
Microadjustment question
shedberg
Jan 07, 2014 17:28 |  #1
I just got a 135 f/2L in a trade, and on my 6D I had to microadjust it to +5. On my 7D it seems to be fine at 0. I haven't done any microadjusting on any other lens with either camera, and they seem to be fine at 0. Is this normal, or should I be adjusting all lenses on my 6D to +5?
6D / 7D / 16-35 II / 35 2.0 IS / 60 macro / 85 1.8 / 135 2 / 100-400 / 430EX II
maverick75
Joined May 2012
Jan 07, 2014 17:31 |  #2
No, all lenses will be different.
Some many need more,less, the same or even none.
Bodies will also be different.
shedberg
Jan 07, 2014 17:34 |  #3
If it's an issue with that particular lens, it should need to be adjusted on both cameras though, right? If it's an issue with that particular camera body, all lenses should need to be adjusted on it?
maverick75
Joined May 2012
Jan 07, 2014 17:43 |  #4
Say you have a camera out of tolerance at -3, then you have a lens that is +1 but another at -3.
If you see it to +1 on all the lenses then the one at -3 will still be off.
The other camera might only be out of tolerance at -1, so when use lens #1(that is at -1) it won't need any because the lens off sets it.
That's why it best to calibrate each lens for each body differently.
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Jan 07, 2014 17:59 |  #5
Perfectly normal; as long as you have an adjustment value that works, don't overthink it. Especially with that little of an adjustment needed, there's nothing wrong with the gear.
JeffreyG
Gallery: 42 photos
Jan 07, 2014 18:03 |  #6
My 85L II needs -17 on the 1D4 but takes +4 on the 5D Mark III. And the really funny part is that it works just fine on the old 5D I gave my daughter that does not even allow for MA.
ejenner
Gallery: 98 photos
Joined Nov 2011
Jan 07, 2014 18:04 |  #7
shedberg wrote in post #16586424 (external link)
You might think. And I've seen it explained this way. However, the reality is that it varies between lenses and bodies in no obvious pre-defined manner.
I have 3 MA bodies and several primes and nothing is consistent. In other words I cannot say one body is 'off' or even that a particular lens is 'off'.
For instance my Sig is +12 a near distances and 0 at infinity on both my 7D and 5DII. On the 5DIII it is 0 near and far.
My 135L is 0 on the 5DII, -5 on the 7D and 0 on the 5DIII.
135 + 1.4 TC is -5 on the 5DII, 0 (or +3, I don't remember, but I know it goes the opposite way as the 135 without the TC) on the 7D and untested on the 5DIII.
My 50 1.4 is zero on all 3 (within AF accuracy)
My 100L is zero on the 5DII, +5 on the 7D and 0 on the 5DIII
Now if you can make sense of that from a 'lens is out by this much and camera out by this much perspective', then good luck. The 135L with and without the TC dispelled that myth for me when I first got the 7D and tried to compare with what it did on the 5DII.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
Snydremark
Gallery: 66 photos
Jan 07, 2014 18:09 |  #8
Have a quick read through these, as good explainations:
http://www.lensrentals​.com …lens-and-camera-variation (external link)
http://www.lensrentals​.com …s-is-soft-and-other-myths (external link)
http://www.lensrentals​.com …s-is-soft-and-other-facts (external link)
Spuddyd
Gallery: 25 photos
Joined Sep 2012
Jan 07, 2014 18:10 as a reply to  @ JeffreyG's post |  #9
My 24-105 needed +5 on my 7D, the Sigma needed -15.
On my 5D3, the Canon lens is spot on @+-0 yet the Sigma needs +5.
Don't sweat it and just adjust as required and go shoot (IMHO). ;)
5DMk4, 16-35 f4L IS, 24-105 f4 L IS, Sigma 35 f1.4 ART, Sigma 50 f1.4 ART, Sigma 70-200 f2.8 OS, Sigma 1.4 and 2x converters, Lightroom CC.
The difference between genius and stupidity is that genius has it's limits!
flickr (external link), Photobucket (external link), My 500PX (external link)
shedberg
Jan 07, 2014 18:11 |  #10
ejenner wrote in post #16586491 (external link)
This is very comforting. Still, I think I'll run all my lenses through the paces just to see.
shedberg
Jan 07, 2014 18:18 |  #11
"So for those of you who spend your time worried about getting “the sharpest possible lens”, unfortunately sharpness is rather a fuzzy concept."
Good line from the first article...
shedberg
Jan 07, 2014 18:19 |  #12
Spuddyd wrote in post #16586509 (external link)
My concern was that there should be some kind of constant involved... I guess there isn't one after all!
King22
Joined Dec 2013
Jan 08, 2014 05:30 |  #13
How did you go about adjusting the 24-105, im kind of confused about MFA zooms...any advice would be much appreciated.
7D| Σ 50mm f/1.4 | 24-105 L
Spuddyd
Gallery: 25 photos
Joined Sep 2012
Jan 08, 2014 17:12 as a reply to  @ King22's post |  #14
You can spend a few £\$'s on a gizmo that is basically 2 rulers at near right angles to each other. the idea being that the (near) horizontal ruler gives an indication of how far "out" your lens is having focused on the vertical ruler.
I stuck a stick in the ground and focused the lens on it having laid a tape measure on the ground beside it. that way, by looking for the sharpest point on the tape measure, you can MFA your lens with ease although you might need several shots to confirm absolute tack sharp focus adjustment.
Use your lens on a tripod, IS off, at the normal aperture you would use and both minimum zoom + full zoom to get the stick in the center of the focus field. Full zoom as a starting point as this gives the shortest effective DOF.
Hope this is clear enough and helps.
3,158 views & 0 likes for this thread, 7 members have posted to it.
954 guests, 109 members online
