Jan 08, 2014 19:19 | #1 Have no idea what this was used for, someone found it in the grass and stood it up. It had probably been laying in the grass for 50 years.
OhLook insufferably pedantic. I can live with that. 24,926 posts Gallery: 105 photos Best ofs: 2 Likes: 16366 Joined Dec 2012 Location: California: SF Bay Area More info | Jan 08, 2014 19:21 | #2 My guess would be wagon wheel. PRONOUN ADVISORY: OhLook is a she. | Comments welcome
Jan 08, 2014 19:23 | #3 OhLook wrote in post #16589458 My guess would be wagon wheel.
grayline Member 247 posts Likes: 19 Joined Dec 2013 Location: Newnan Georgia More info | Jan 08, 2014 19:35 | #4 Its a Rake wheel.... for Hay or straw It would Have Tines on it that would be offset and rake and turn as it was pulled. The holes in the center part meant it was one of the middle wheels because it would have had a gear bolted to it to turn the other wheels in unison. If you look close you can see where The tines were welded on... Gear List :EOS 70D ,Sigma 50mm 1.4,Tamron 18-270, Canon 18-55,Canon HFM31,Canon SX280HS,Olympus E-10 ,
Jan 08, 2014 19:44 | #5 grayline wrote in post #16589506 Its a Rake wheel.... for Hay or straw It would Have Tines on it that would be offset and rake and turn as it was pulled. The holes in the center part meant it was one of the middle wheels because it would have had a gear bolted to it to turn the other wheels in unison. If you look close you can see where The tines were welded on... That makes perfect sense, the land this is on used to be farmland. Till the gubment took it to build an airfield.
| Latest registered member is Thunderstream 1211 guests, 121 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
