Thread started 09 Jan 2014 (Thursday) 04:36
Canon 600D problem...baffled
akelly1708
Joined Jan 2014
Jan 09, 2014 04:36 |  #1
Can someone please help with this issue. I've had a 600D for a few months, learning more and more, practising and reading up on information. It recently encountered a problem that has been killing me for days. In bright enough conditions in all modes, AutoISO only picks 3200. By manually choosing a suitable ISO, 3200 is the only one that will give me a bright enough image. I can also only use extremely slow shutter speeds to coincide with this. In essence, it is doing the opposite of what should be happening. In light conditions it will only react to high iso and slow speeds. In darkness auto iso will pick a lower iso, 400/600/800. By trying to force it, same problem occurs. Like I said, doing opposite of what it should be doing. I haven't heard of this problem before. I have reset settings numerous times. Just started happening out of nowhere. Any help would be brilliant. Cheers.
watt100
Jan 09, 2014 06:43 |  #2
akelly1708 wrote in post #16590392 (external link)
what metering are you using? (eval, spot, center, etc.) is it so dark you actually need a flash? many experienced users choose an appropriate ISO (and flash) for really low light situations
akelly1708
Joined Jan 2014
Jan 09, 2014 07:40 as a reply to  @ watt100's post |  #3
This is happening in light conditions, conditions usually viable for isos of 100/200. I usually set the iso according to the scene, that is the problem. Even in daylight I can only get a suitable shutter speed at 1600/3200. Daylight shooting at 100/200 will only let me shoot a bright enough image at 1/8 or so and when handheld can lead to a fair bit of blur. I do a lot of amateur shooting, during daylight on aperture priority. Dependent on situation, I usually set an iso of 100/200/400. Shutter speed is determined by default. If I try and do that now, I'm getting ridiculously slow speeds, 1/8 and below. Switching between the metering modes doesn't change anything. This wasn't occurring until recently, hence my worry. I am still a newb in essence so if I am missing something glaringly obvious I do apologise.
watt100
Jan 09, 2014 07:44 |  #4
akelly1708 wrote in post #16590641 (external link)
you may have accidentally turned down exposure compensation or something, I get nothing like that with good light
Frodge
Joined Nov 2012
Jan 09, 2014 07:47 |  #5
As said above. Exposure compensation.
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
akelly1708
Joined Jan 2014
Jan 09, 2014 07:50 as a reply to  @ watt100's post |  #6
I wasn't until recently. Exposure compensation set to 0. I've tried resetting settings numerous times to no avail. Sensor problem I guess. Never seen or heard of the problem before. Even if I'd of changed a setting by accident, clearing all settings would revert it back to factory default. This is with the kit lens 18-55 I may add but I can't imagine it being a lens issue. I have a 50mm prime in the post atm, will try with that.
watt100
Jan 09, 2014 07:53 |  #7
akelly1708 wrote in post #16590670 (external link)
look thru the viewfinder and see if the needle is at "0" in Av mode
akelly1708
Joined Jan 2014
Jan 09, 2014 07:57 |  #8
Yes. But only at 1600/3200 with slow speeds. At 100/200/400 it's underexposed with stupidly slow speeds...
If I set iso to auto, it does the same, picks 1600/3200 and 1/8 and lower.
Frodge
Joined Nov 2012
Jan 09, 2014 07:58 |  #9
Is there a filter on the lens....
John ­ from ­ PA
Joined May 2003
Jan 09, 2014 08:00 |  #10
First of all, unless you have highly customized the camera, simply do a factory reset and see if the issue goes away. If you do have some custom settings, examine them first and take some notes so you can restore the settings after the reset.
akelly1708
Joined Jan 2014
Jan 09, 2014 08:01 |  #11
Nope, basic kit lens as standard. No filter or hood.
akelly1708
Joined Jan 2014
Jan 09, 2014 08:02 |  #12
By factory reset, do you mean simply 'clear all camera settings' from the drop menu?
SkipD
Joined Dec 2002
Jan 09, 2014 08:02 |  #13
Try another lens. I'm suspecting that bad communication from the lens may be possible.
Skip Douglas
-MasterChief-
- B E L I E V E -
Jan 09, 2014 08:05 |  #14
post a pic with EXIF?
akelly1708
Joined Jan 2014
Jan 09, 2014 08:06 |  #15
I will try the 50 when delivered. Thanks for your replys guys. Like I said, if there was something obvious I am missing, I do apologise but this has only recently starting happening.
4,568 views & 0 likes for this thread, 12 members have posted to it.
1677 guests, 103 members online
