Can someone please explain the stabilizer modes on this lens.
I understand the stabilizer on-off, but why is there two options of stabilizer modes ? and how to use them.
Jan 10, 2014 11:10 | #1 Can someone please explain the stabilizer modes on this lens.
gonzogolf dumb remark memorialized More info | Jan 10, 2014 11:11 | #2 Mode 1 is for regular stabiization. Mode 2 is panning mode so your image is stabilized in one direction but not in the other.
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | Jan 10, 2014 11:15 | #3 gonzogolf wrote in post #16594076 Mode 1 is for regular stabiization. Mode 2 is panning mode so your image is stabilized in one direction but not in the other. Yes. Taylor
Snydremark my very own Lightrules moment More info | Jan 10, 2014 11:18 | #4 It depends on the direction of the pan, for Mode 2. It stabilizes in the direction you're not moving, which is one of the things that makes it useful for shooting airshows, as well. If you're panning left/right, it stabilizes up/down, if you're panning up/down, it stabilizes left/right. - Eric S.: My Birds/Wildlife
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | Jan 10, 2014 11:23 | #5 Snydremark wrote in post #16594096 It depends on the direction of the pan, for Mode 2. It stabilizes in the direction you're not moving, which is one of the things that makes it useful for shooting airshows, as well. If you're panning left/right, it stabilizes up/down, if you're panning up/down, it stabilizes left/right. Good to know, I thought it was just side to side. Taylor
Jan 10, 2014 11:32 | #6 Cheers.
Snydremark my very own Lightrules moment More info | Jan 10, 2014 12:08 | #7 If you're using the 100-400 on a tripod, turn off IS. It is one of the older models that doesn't detect that a tripod is in use and can actually *cause* blur from the movement of the IS element when it isn't required. - Eric S.: My Birds/Wildlife
ScottM Goldmember More info | Jan 10, 2014 12:36 | #8 Snydremark wrote in post #16594245 If you're using the 100-400 on a tripod, turn off IS. It is one of the older models that doesn't detect that a tripod is in use and can actually *cause* blur from the movement of the IS element when it isn't required. ...and just as important, remember to turn it back on after removing the camera+lens from the tripod. On more than one occasion, I have forgotten to do this, and then later when shooting handheld wondered if I'd had too much coffee because the image in my viewfinder was so shaky.
bps Cream of the Crop 7,607 posts Likes: 406 Joined Mar 2007 Location: California More info | Jan 10, 2014 12:40 | #9 Well, there you have it. This is one of the most concise and highly accurate threads I've ever seen!
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | Jan 10, 2014 13:30 | #10 bps wrote in post #16594353 Well, there you have it. This is one of the most concise and highly accurate threads I've ever seen! Bryan No it isn't! Taylor
Jan 10, 2014 13:55 | #11 Some great advice here.
Snydremark my very own Lightrules moment More info | Jan 10, 2014 15:42 | #12 @Taylor: Go away - Eric S.: My Birds/Wildlife
Jan 10, 2014 19:48 | #13 Snydremark wrote in post #16594096 It depends on the direction of the pan, for Mode 2. It stabilizes in the direction you're not moving, which is one of the things that makes it useful for shooting airshows, as well. If you're panning left/right, it stabilizes up/down, if you're panning up/down, it stabilizes left/right. I didn't realise that. I thought it was just horizontal, but I've just checked the manual and you're dead right. Canon 7D2 · 16-35 f/4L IS · 17-55 f/2.8 IS · 18-135 f/3.5-5.6 IS STM · 50 f/1.8 · 100 f/2.8 Macro · 100-400L IS II
HuskyKMA "Now what?" 1,749 posts Likes: 1 Joined Feb 2008 Location: Castle Rock, WA More info | Jan 10, 2014 20:19 | #14 Snydremark wrote in post #16594245 If you're using the 100-400 on a tripod, turn off IS. It is one of the older models that doesn't detect that a tripod is in use and can actually *cause* blur from the movement of the IS element when it isn't required. Is there a list or other resource somewhere that lists what lenses this applies to? (Besides reading my manuals! Canon 40D w/ BG-E2N Grip| 400mm f/5.6L | 70-200mm f/2.8L IS II | 28-135mm f/3.5-5.6 IS | 10-22mm f/3.5-4.5 | Gitzo GT3541LS w/ RRS BH-55
Snydremark my very own Lightrules moment More info | Jan 10, 2014 20:55 | #15 http://www.dlcphotography.net/TripodAndIS.htm - Eric S.: My Birds/Wildlife
| Latest registered member is semonsters 1089 guests, 118 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
