I'm looking at the one without the clamp. At Adorama and B&H they show it with a threaded disk. Does anyone know if this comes with a 3/8" stud to fit a RRS B2-Pro clamp or do I have buy that stud separately? Thanks guys!
Jan 10, 2014 11:22 | #1 I'm looking at the one without the clamp. At Adorama and B&H they show it with a threaded disk. Does anyone know if this comes with a 3/8" stud to fit a RRS B2-Pro clamp or do I have buy that stud separately? Thanks guys! Chris
Jan 10, 2014 12:03 | #2 The Z1 without the clamp has two versions. One has a 1/4"-20 stud on top, the other a 3/8"-16. Just make sure you order the right one. - John
Jan 10, 2014 12:13 | #3 Thanks sawsedge! This is exactly what I needed to know. sawsedge wrote in post #16594232 The Z1 without the clamp has two versions. One has a 1/4"-20 stud on top, the other a 3/8"-16. Just make sure you order the right one. Those disks can be removed via a small 11mm socket, assuming they don't use a strong threadlocker. The one I bought recently did not have any threadlocker, so that disk can be removed and replaced by a clamp of choice. This thread has more information on the threadlocker: https://photography-on-the.net …/showthread.php?t=1339086 Under the disk is a stem with an M6-threaded hole and an anti-twist boss. You can attach a compatible QR clamp of choice to that stem. I assume that is your goal? Chris
Jan 10, 2014 12:17 | #4 I just looked up the B2-pro and I don't think that has the cutouts for the boss used by the Z1 stem. - John
Jan 10, 2014 12:31 | #5 Thanks again sawsedge! sawsedge wrote in post #16594279 I just looked up the B2-pro and I don't think that has the cutouts for the boss used by the Z1 stem. You can either screw the clamp directly onto the 3/8" stud version, or you'll need another clamp, like this one: http://www.reallyrightstuff.com/s.nl/it.A/id.3608/.f Chris
I want to make sure I got this right... Chris
Jan 10, 2014 14:44 | #7 That's the right ballhead, but you'll have to ask RRS to be sure. It sounds right but I'd check with them. - John
Jan 10, 2014 14:56 | #8 Thanks again sawsedge! sawsedge wrote in post #16594651 That's the right ballhead, but you'll have to ask RRS to be sure. It sounds right but I'd check with them. Chris
seres Senior Member 580 posts Likes: 40 Joined Apr 2013 More info | Jan 10, 2014 15:00 | #9 cmoy wrote in post #16594427 I want to make sure I got this right... I order this... http://www.adorama.com/AWMBZ1SP38.html and this... http://www.reallyrightstuff.com/s.nl/it.A/id.3608/.f No need for a 3/8" stud because the RRS B2-Por II comes with a flat headscrew? That is correct. I ordered the same products a few months ago, and it worked perfectly (just be sure the screw included with the RRS clamp is an M6 screw, and not the 1/4x20 screw). —Eric
Jan 10, 2014 15:04 | #10 GREAT! Thanks seres! seres wrote in post #16594681 That is correct. I ordered the same products a few months ago, and it worked perfectly (just be sure the screw included with the RRS clamp is an M6 screw, and not the 1/4x20 screw). Chris
Jan 11, 2014 07:57 | #11 All the above is correct, you have the right Z1 and screw knob clamp from RRS. When the Z1 arrives, take it to Home Depot or wherever you buy the 11mm socket because you'll need a socket with a thin wall; there isn't much room between the edges of the bolt on the screw and the base plate. ~Peter
Jan 11, 2014 08:37 | #12 Thanks Peter! Ordered the RRS clamp. Now I need to decide if I want to trek to B&H or have it shipped peter_n wrote in post #16596314 All the above is correct, you have the right Z1 and screw knob clamp from RRS. When the Z1 arrives, take it to Home Depot or wherever you buy the 11mm socket because you'll need a socket with a thin wall; there isn't much room between the edges of the bolt on the screw and the base plate. RRS also make a self-adjusting lever clamp that now fits all types of plates - no adjustment necessary and they work just fine. I just put one on my Z1. Chris
Jan 12, 2014 10:02 | #13 It's likely that quite a few have sold recently since it got out that Arca are now using a very powerful threadlocker to secure their clamps. If you buy from B&H, I think the head with the ball locking knob on the left has a 1/4" screw, and the 3/8" screw version has the locking knob on the right. I would check their web site before ordering, and when it arrives try to take the round base off as soon as you get it. You may be lucky and get old stock. ~Peter
Jan 13, 2014 11:45 | #14 Thanks again Peter! I picked up the Z1 yesterday. To our surprise B&H was not crazy crowded like usual! peter_n wrote in post #16599094 It's likely that quite a few have sold recently since it got out that Arca are now using a very powerful threadlocker to secure their clamps. If you buy from B&H, I think the head with the ball locking knob on the left has a 1/4" screw, and the 3/8" screw version has the locking knob on the right. I would check their web site before ordering, and when it arrives try to take the round base off as soon as you get it. You may be lucky and get old stock. Chris
Jan 14, 2014 07:58 | #15 Great! The ball has a diameter of 54mm and the Markins Q20 is a nearer model in terms of size to the Z1. I think you'll enjoy using it a lot, it's a very solid head. ~Peter
| Latest registered member is Niagara Wedding Photographer 1109 guests, 126 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
