Thread started 10 Jan 2014 (Friday) 21:42
I need to confirm some lighting stuff before i splurge..
Ev0d3vil
Joined Dec 2013
Jan 10, 2014 21:42 |  #1
Okay, i'm looking to get a 430exii and the yn-622C triggers. If i mount them on my camera, by right i'm able to trigger it off camera right? Does it work this way or i have to have them in line of sight which i found out yesterday between my speedlites which i've loaned?
frozenframe
Gallery: 189 photos
Joined Jun 2013
Jan 10, 2014 21:54 |  #2
I happen to use the same. Right now just a pair of 430 EXII and 2 sets of the Yongnuo 622c. Simply, they're wireless radio signal transceivers. So you don't need line of sight. Put one of the triggers on your camera, this acts as the transmitter. Put your flash on another trigger, which will then act as the receiver. You will need to take a little time to read about the Youngnuo 622c. A few threads down in the Yongnuo YN-622c Thread you can look in CliveyBoy's sig for a link to a fantastic PDF document he's published that will help you fully understand them.
Ron
My Gear List
Ev0d3vil
Joined Dec 2013
Jan 10, 2014 22:01 |  #3
Right thanks! i'm planning to use them in a softbox for some portraiture but i'm not pretty sure whether it will work!
frozenframe
Gallery: 189 photos
Joined Jun 2013
Jan 10, 2014 22:02 |  #4
Ev0d3vil wrote in post #16595631 (external link)
Yep, should work. Yongnuo is one of the great affordable answers to Pocket Wizards.
Ron
My Gear List
Ev0d3vil
Joined Dec 2013
Jan 10, 2014 22:12 |  #5
So it works this way am i right? One trigger on my camera hotshoe, a receiver under each flash that I want to have them? So in a way, they're acting like masters to the flashes then?
windpig
Chopped liver
Jan 10, 2014 22:20 |  #6
Ev0d3vil wrote in post #16595653 (external link)
yes.
BTW, what camera are you shooting?
Go ahead, spin the wheel.
Ev0d3vil
Joined Dec 2013
Jan 10, 2014 22:56 |  #7
windpig wrote in post #16595671 (external link)
yes.
T2i/550D. Will it be okay?
Dave ­ Jr
Jan 11, 2014 00:07 |  #8
Yes, but use a shutter speed of 1/125 or 1/160 max in order to avoid a slight black bar at bottom or right of frame.
Dave Jr - MN
5 (external link)px | Gear
Ev0d3vil
Joined Dec 2013
Jan 11, 2014 00:09 |  #9
Dave Jr wrote in post #16595896 (external link)
AH oh dear, why is that so? How about if i decide to use HSS?
gremlin75
Jan 11, 2014 01:27 |  #10
Ev0d3vil wrote in post #16595901 (external link)
I'm curious about the answer to that too as I use the 622c's and have never had an issue with max sync speed (60D). Yongnuo's cheaper manual triggers limit sync speeds but the 622c should not, and for me do not, limit the max sync speed. 1/250 and no shutter curtain in the photo
The 430ex II is capable of HSS so you will have no issues with HSS with them and your camera as well
Ev0d3vil
Joined Dec 2013
Jan 13, 2014 09:06 |  #11
Is the YN622C compatible with the 420EX?
Aressem
Gallery: 39 photos
Jan 13, 2014 09:13 |  #12
gremlin75 wrote in post #16595991 (external link)
Flash sync speeds vary from camera to camera. My 7D syncs up to 1/320 whereas the 5D II syncs to 1/160. I can't confirm the sync speed on the t2i but I am sure Dave knows what he is talking about. Only one way to be sure though. TRY IT. ;)
Ryan Mackay WEBSITE (external link) | FACEBOOK (external link) | GEAR LIST | Buy & Sell Feedback: 1, 2, 3, 4, 5
Dave ­ Jr
Jan 13, 2014 10:18 |  #13
The 622c with any camera has a slight signal delay. You won't quite get a clean frame at 1/200th using a 5dII or 5dIII. Whatever your camera's max sync speed is, you'll need to drop the shutter speed a bit to allow for the delay. Either that, or frame more loosely so you can crop out the shutter shadow. I'm not sure what the max shutter sync is for a T2i, that is why I suggested either 1/125 or 1/160. As Ryan mentions, try it and see. The best way to see the speed at which shutter shadow becomes an issue is to shoot a white background and start at max sync, and lower down incrementally until the shadow is gone.
BTW, when I first received the 622c's, I was happily clicking away at 1/200th and would have sworn that there was no shutter shadow. You won't notice it in many shots, but that does not mean it is not there. Shooting on white will make it much more apparent.
Dave Jr - MN
sirquack
Gallery: 66 photos
Joined Jan 2013
Jan 13, 2014 10:27 |  #14
I have the T3i and my max sync speed is 1/200th. I use the 622c with a YN 565 ex and I have not seen the shutter curtain even at max sync speed. I don't know if the system compensates for the sync or what. But I have, so far at least, not had to cut back my shutter from max to keep the shutter curtain out of the image.
Can others using the 6D or the 5D II or 5D III confirm as I am looking to get a second body and those are the three I am considering. I want to see if others see problems with those bodies and the 622c flash set up.
Name is Ron.
Bodies - 6D/5D3/7D2-Gripped
Lenses - Canon 17-40 F4/24-70 F2.8 II/85 F1.8/Canon 70-200 F2.8 II/F4/Sigma 30 DC/Tamron 150-600
Website (external link)
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Jan 13, 2014 10:29 |  #15
sirquack wrote in post #16601814 (external link)
The max sync on a 6D is 1/160. Many 5D and 5DII users have reported having issues above 1/160 when using any brand of wireless triggers as any delay in triggering catches up with the larger shutter.
2,586 views & 0 likes for this thread, 9 members have posted to it.
1006 guests, 185 members online
