Thread started 12 Jan 2014 (Sunday) 22:08
mirror cover completely loose
canon7000d
Joined Jan 2014
Jan 12, 2014 22:08 |  #1
i brought a refurbished canon 5d mark 2 on e bay. it was in pristine condition for 1250. that was 3 weeks ago. today the mirror cover fell off.
i don't know at this point is this a minor repair or major repair till i take it into store 9750 actuations according to seller
John ­ from ­ PA
Joined May 2003
Jan 13, 2014 06:41 |  #2
As you can see by http://www.dpreview.co​m/forums/thread/327209​7 (external link) this is not an unknown issue, even going back to the classic which Canon would repair for free. Some people have had good luck getting the later 5D models also fixed for free.
You say it was a refurb from eBay. Who ultimately was the vendor? Private seller or someone like B&H or Adorama. If private seller your likely best recourse is through what eBay or Paypal offers. If B&H or Adorama they have exchange programs for I think 30 days and warranties for a year. I personally would suggest the repair of what you have through the best option. Getting a pristine 5DII with less than 10000 clicks is a good thing.
rrblint
Gallery: 84 photos
Joined May 2012
Jan 13, 2014 07:50 as a reply to  @ John from PA's post |  #3
There is no such thing as a "mirror cover" in the camera. Perhaps it is just the focus screen that fell out? If so, it is an easy fix.
Mark
Lowner
"I'm the original idiot"
Jan 13, 2014 10:25 |  #4
Like Mark I'm confused by the description "mirror cover". Do you mean the mirror has come unglued?
Richard
canon7000d
Joined Jan 2014
Jan 13, 2014 18:09 |  #5
rrblint wrote in post #16601479 (external link)
yes according to seller he thinks i dislodged focusing screen when i took a lens off .weird scenario is that possible. thanks for your comment
John ­ from ­ PA
Joined May 2003
Jan 13, 2014 18:48 |  #6
These instruction show you how to change screens...http://www.focusingscr​een.com/work/5d2en.htm (external link)
Go to step 13 and follow how to reinstall.
the ­ flying ­ moose
Jan 13, 2014 19:11 |  #7
Mine did that and I ended up getting a scratch on the mirror. Cost me a few hundred dollars to deal with.
canon7000d
Joined Jan 2014
Jan 14, 2014 08:36 |  #8
John from PA wrote in post #16603087 (external link)
where do you get that tool from? have looked on e bay does it come with the focusing screen canon wants 300d up front for any repair
canon7000d
Joined Jan 2014
Jan 14, 2014 08:41 |  #9
John from PA wrote in post #16601351 (external link)
i got the camera from a private seller on e bay. there was a warranty he had shutter replaced but don't think my problem is covered on that warranty. i am worried same scenarion could happen again.seems to me i have a very delicate camera mechanism here.
a camera assistant said she would attempt to put screen back for me
amfoto1
Jan 14, 2014 09:18 |  #10
canon7000d wrote in post #16604422 (external link)
It is not a common problem for the mirror to come unglued on the 5D Mark II. That was a known problem with the original 5D, but was resolved with that model in later production and is practically unheard of with 5DII. As others have suggested I suspect it's just a prob with the focus screen frame popped open, and hopefully the screen hasn't fallen out and gotten damaged.
You don't have to have that tool to put the focus screen back in place. It helps, but a pair of standard plastic tweesers will work too. If necessary, you can release that latch with a fingernail (where they show using the tool). You might even be able to use your bare fingers to position the focus screen within the frame.
However try it is best to use a plastic tool or to only handle the focus screen by the edges or, even better, only by the little tab that protrudes from one side. Make sure the frame is open. Place the screen within the frame (or just make sure it's not askew in the frame). Then carefully swing the frame up until that latch on the front snaps it into place.
If the focus screen is damaged and needs to be replaced, it is easily user replaceable and a new one costs $35 (from many sources online). You have a choice of three types of focus screens.... EG-A is the standard one. EG-S is a high precision screen (aids manual focus, with f2.8 and faster lenses), and EG-D screen with a grid to help with composition. The tool you see at that website is included with the Canon screens.
While replacing the focus screen, try not to touch the mirror right below it. It's easily damaged.
If you contacted Canon and they quoted you $300, that was probably for replacement of the mirror. Your description of the problem originally sounded as if there was a problem with that. Now it sounds as if it's only a problem with the focus screen.
John ­ from ­ PA
Joined May 2003
Jan 14, 2014 11:22 |  #11
Most likely you can therefore forget using the term "refurbished", at least as the term applies when used by Canon, Adorama, or B&H.
As others have indicated the tool comes with the focusing screen. But to reinstall the screen I don't think the tool is essential.
tzalman
Fatal attraction.
Jan 14, 2014 17:05 |  #12
canon7000d wrote in post #16602992 (external link)
No, it is absolutely not possible. The seller is blowing smoke and trying to avoid responsibility. It is likely that at some time he removed the screen, either to replace it or for some other reason, and did not put it back in properly. A less likely scenario is that when the shutter was replaced the technician removed the screen and did not seat it properly when returning it.
Elie / אלי
HyperCams
Gallery: 6 photos
Jan 14, 2014 17:28 |  #13
OR...maybe it popped loose during shipping..I have seen shipping do some pretty crazy things to sensitive equipment, especially when Ace Ventura is your delivery guy! lol
I doubt it though..I would have to say the seller probably installed it improperly, like tzalman mentioned..and it just eventually worked it's way loose..
Not a big deal though..(as many have already commented)
Brent Oliver
HyperCams & Mods (external link)/Oliver Digital Images
My Flickr (external link)
Feedback and Gear
canon7000d
Joined Jan 2014
Jan 15, 2014 20:38 |  #14
HyperCams wrote in post #16605793 (external link)
thanks for all the members who added imput to this posting. i will; attempt to put the focusing screen myself glen
msowsun
"approx 8mm"
Gallery: 18 photos
Jan 18, 2014 17:12 |  #15
canon7000d wrote in post #16600770 (external link)
Did you use the camera for 3 weeks before the focus screen popped down? That is not the fault of the previous owner. Even if it happened the day you got it, I would just chalk it up to bad luck. The tab that releases the screen is not protected and I suspect it gets bumped sometimes when you change lenses.
I also bought a used 5D Mk II and about 1 year later the same thing happened to me. I just popped it back up and it never came loose again. After you close it up you may see some extra dust in there because you had it open for so long. If you see a lot of dust, open it up again, take your rocket blower and try to blow the dust out and then close it up again.
If you do a Google search you will see that it happens to a lot of other people too. https://www.google.ca …+ii+focus+scree​n+fell+out (external link)
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/Photo14/5d2.jpg~original
4,557 views & 0 likes for this thread, 9 members have posted to it and it is followed by 2 members.
1679 guests, 103 members online
