Has anyone bought a cheap gimbal head for a tripod off ebay? I can't justify spend $400+ for a gimbal to support my sigma.
Africanphoto Member 124 posts Joined Sep 2012 Location: Australia More info | Jan 13, 2014 20:32 | #1 Has anyone bought a cheap gimbal head for a tripod off ebay? I can't justify spend $400+ for a gimbal to support my sigma. Canon 7D, Canon 100mm L F2.8, Sigma 120-300mm F2.8 OS, Sigma 50mm F1.4, Canon 430 ex II, Sigma 2x teleconverter, Kenko extension tubes, Vello flash cord And a few bits and peices and a Yashica 635!!!
SteveJa Goldmember 2,137 posts Likes: 23 Joined Dec 2008 Location: Nebraska More info | Jan 13, 2014 20:58 | #2 I have a flashpoint gimbal, they are $240 at adorama. Not bad for the money, but it is not for a big lens. I used this one for my 100-400, but now that I have a 500f4 I bought a bigger one.
joeseph "smells like turd" More info | Jan 13, 2014 21:47 | #3 how much can you justify spending on repairs if a cheap gimbal breaks? some fairly old canon camera stuff, canon lenses, Manfrotto "thingy", and an M5, also an M6 that has had a 720nm filter bolted onto the sensor:
Jan 13, 2014 21:54 | #4 Hello, "Then the coal company came with the world's largest shovel
5280Pics Goldmember More info | Jan 13, 2014 22:47 | #5 Take a look into the reviews of the Opteka gh1 gimbal. Not too bad for under $200. _______________
tomj Senior Member 706 posts Likes: 61 Joined May 2010 More info | Jan 14, 2014 09:06 | #6 I have Beike gimble head - the Opteka is the same head re-branded. It's available on ebay for under $90.
Jan 14, 2014 16:23 | #7 Have a look at the UK based Lensmaster heads. I use an RH1 moel for my 300 F2.8 IS and find it pretty good. It is not as good as my Wimberley 2 but it is smaller, lighter and MUCH cheaper, it also comes with 2 QR plates (Arca type). I believe they ship overseas. Life is for living, cameras are to capture it (one day I will learn how!).
Jan 15, 2014 06:05 | #8 If you do go for a cheaper full (i.e., not a Sidekick-type) gimbal then make sure it allows you to adjust the height of the lens. This is essential for getting everything perfectly balanced - so that you can have the friction really low yet still be able to move everything with one finger and have it stay in place when you stop moving it. Frank Hollis - Retired mass spectroscopist
Jan 18, 2014 11:52 | #9 Hello, "Then the coal company came with the world's largest shovel
Jan 18, 2014 13:21 | #10 jtmiv wrote in post #16615823 It does have the capability to adjust the height on the mounting plate. But only in three positions, not enough to get proper balance unless you're lucky. Frank Hollis - Retired mass spectroscopist
Jan 18, 2014 13:37 | #11 Dear Hollis, "Then the coal company came with the world's largest shovel
CScottIV I should keep some things to myself! More info | Jan 18, 2014 13:40 | #12 +1 on Frank's comments. Charles
Jan 18, 2014 18:34 | #13 C Scott IV wrote in post #16616057 +1 on Frank's comments. The sidekick style gimbals would take care of lining up the center of the lens. It isn't an option for me because sometimes I use the L-Bracket on the 7D with the kit lens. The L-Bracket does not have stop screws and could potentially slide through the clamp. It is best to let gravity work for you rather than against you. Unfortunately the center of the lens is almost never the right place to balance a lens. This is because the camera you attach to it is almost always bottom heavy. This is even more pronounced in gripped bodies and pro bodies. The center of the lens is almost always positioned just above the vertical pivot - hence Hollis' comments. Life is for living, cameras are to capture it (one day I will learn how!).
CScottIV I should keep some things to myself! More info | Jan 18, 2014 20:55 | #14 Thanks for clarifying. One could use a nodal rail for that but a full gimbal with adjustable height is the more practical solution. Charles
Jan 19, 2014 12:37 | #15 C Scott IV wrote in post #16616991 Thanks for clarifying. One could use a nodal rail for that but a full gimbal with adjustable height is the more practical solution. I feel a full gimbal is the best solution but they are heavier and more expensive! I wouldn't rule out sidekick type heads (as my Lensmaster is one and it works OK) but I would suggest trying before buying. Life is for living, cameras are to capture it (one day I will learn how!).
| Latest registered member is ANebinger 1092 guests, 173 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
