Thread started 05 Feb 2006 (Sunday) 03:37
What am I doing wrong?
shniks
Joined Jan 2004
Feb 05, 2006 03:37 |  #1
Hello, I was out shooting today with my 70-200 F4L lens, I havent used it much so I am still learning. I am getting a lot of soft images, I dont know what I am doing wrong. I have performed focus tests and it seems to be spot on, so I dont think its that. Images taken at a shorter focal length usually look great, is it just because I am shooting at 200mm?
Here is some examples:
at 100%
at 100%
exif for both is the same:
File Name
Camera Model Name
Canon EOS 10D
Shooting Date/Time
5/02/2006 12:39:19 PM
Shooting Mode
Aperture-Priority AE
Tv( Shutter Speed )
1/400
Av( Aperture Value )
5.6
Metering Mode
Evaluative
Exposure Compensation
ISO Speed
400
Lens
70.0 - 200.0mm
Focal Length
200.0mm
Image Size
3072x2048
Image Quality
Fine
Flash
Off
White Balance
Auto
AF Mode
One-Shot AF
Parameters
Contrast Normal
Sharpness Normal
Color saturation Normal
Color tone Normal
Color Space
sRGB
File Size
2199KB
stupot
Feb 05, 2006 03:49 |  #2
that looks pretty good to me. 100% crops always look soft, but you never view an image at that scale so its no problem. IMO you've got a good lens:) you've just gotta get yourself closer to the bird:P
the first one does look more blurred than the second though... thats prob due to camera shake or something.
Canon EOS 350D, Sigma 10-20 f4-5.6, 24-105 f4L IS, 70-200 f4L, 300 f4L IS, Kenko 1.4x pro300, 430EX, Apple Powerbook G4
Free filters for your flashgun!
kprince
Feb 05, 2006 04:15 |  #3
Most images can use a little post sharpening.
++I make these (external link)
http://www.redheadwind​screens.com (external link) Custom windscreens for digital hand held audio recorders. DEMOS > Where's your Redhead? (external link)
pehabe
Joined Jul 2003
Feb 05, 2006 04:23 |  #4
hi...
You shot in JPG and with your parameter setting it will come out "soft".
Try to increase your sharpness and contrast parameter.
And like kprince said you could do some unsharp mask with PS.
good luck :D
Peter (external link)
Gallery (external link) Shop (external link)
jjonsalt
Feb 05, 2006 06:42 |  #5
It does seem a tab bit soft to me. Two suggestions come to mind. If I made that shot I would be using center focus only and a tripod (or monopod). try it, see if it makes a difference.
SuzyView
Feb 05, 2006 06:54 |  #6
Fuzzy bird, fuzzy picture. Makes sense to me. ;) :) Don't we have a center focus thing on our 10D's? Would that have helped? The metering seems to be awful sometimes for small far away objects that move at 200 meters away. With that extent of cropping, you did just fine.
TeeJay
Joined Jun 2005
Feb 05, 2006 06:59 |  #7
Hi Shniks,
Did you hand-hold these? Even though you shutter speed was up at 1/400 (which *should* have prevented camera shake being registered) there's still no guarantee. The whole of the image seems a little blurred which would lead me to think the camera wasn't quite steady enough. Even a heartbeat can make the difference if your not on a tripod. I'm not sure that centre-point focusing is the issue (if you get my meaning) as there doesn't seem to be a sharp spot.
Maybe gettingh a little closer and trying to make the subject fill the frame more would help. Also, the lighting seems a little on the flat side.
Nice bird though!
1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea :confused:
Hellashot
Joined Sep 2004
Feb 05, 2006 07:31 |  #8
Your bird is talking up a small portion of your frame. If you were to have it fill up 30% of your frame the clarity and detail would be great. The less pixels your subject takes up, the less detail can be seen.
5D, Drebel, EOS-3, K1000
lenses from 12mm-500mm
StevenRaith
Feb 05, 2006 07:36 |  #9
Get closer, or get more mm.
Either that or try stopping the lense down a couple more notches to increase the DOF a little.
That is all. :)
No matter how good a lense is, if the subject isn;t close enough you won't get that much detail. I can confirm however that burdy there looks quite good to me.
GyRob
Feb 05, 2006 11:09 |  #10
i think your first shot is camera shake the branch is not sharp anywere but sharper on the second shot ,also as other's have said get closer.
Rob.
"The LensMaster Gimbal"
Bookmarks
Feb 05, 2006 15:06 as a reply to  @ GyRob's post |  #11
Opportunities may slip through your fingers in a heartbeat. Shoot first and ask questions later. A bit of PS postprocessing can go a long ways.
shniks
Joined Jan 2004
Feb 05, 2006 16:09 |  #12
Thanks for the replies! I will try shooting with a tripod and stop down to see if it helps, and maybe I am expecting too much detail from such a long distance. I have a feeling it acutally was camera shake, looking back the ones I took at 1/2000 came out really well. This lens is too heavy for me it seems, I need to get used to it.
BTW great PP from kprince and hjoe, I'm going to give it a go too, I originally thought these images were unsaveable.
1,582 views & 0 likes for this thread, 11 members have posted to it.
1059 guests, 104 members online
