Thread started 05 Feb 2006 (Sunday) 04:02
sRGB or Adobe RGB on 350d (digital rebel xt)
Glyno
Feb 05, 2006 04:02 |  #1
Hi, could someone kindly help me understand what colour space setting I really ought to be using on my EOS 350d?
The menu gives me the choice of sRGB or Adobe RGB.
Also, I assume I will a have to set the colour settings (in the Edit menu) in Photoshop 7 to match,?
Any help or advice is very much appreciated.
Thank you, Glyn.
my flickr (external link)
kprince
Feb 05, 2006 04:04 |  #2
and the display settings on your monitor. I use adobe 1998
++I make these (external link)
http://www.redheadwind​screens.com (external link) Custom windscreens for digital hand held audio recorders. DEMOS > Where's your Redhead? (external link)
creighton
Feb 05, 2006 08:42 |  #3
You should at least be aware that many, but not all, print labs use sRGB and not Adobe RGB. If you are printing your photos at home using an inkjet printer Adobe RGB is probably a good choice b/c your printer should be able to accurately print the extra colors in the adobe color space. If you sent those same Adobe RGB prints to a lab that expected an sRGB color space you may find that some of the colors appear washed out. Obviously the results will vary from photo to photo depending on which colors were actually recorded for each image.
Canon 20D
BG-E2 Grip Kit
EF-S 18-55mm f/3.5-5.6 (kit lens)
EF-S 17-85mm f/4-5.6 IS USM
EF 70-200mm f/2.8 L IS USM
ffureel
Joined Feb 2006
Feb 05, 2006 10:14 as a reply to  @ creighton's post |  #4
If you shoot raw, the setting on the camera is irrelevant because you can choose what you want in raw conversion. I use Adobe because it gives a wider colour gamut, but like creighton said, you have to be aware of colour spaces that others use. For example if you display for the web you will need to convert to sRGB.
Glyno
Feb 05, 2006 12:22 |  #5
I understand now guys, thank you very much!
classicsphinx@yahoo.com
Feb 08, 2006 17:48 |  #6
good info
EOS 350D
EF-S 18-55mm 1:3.5-5.6
EF 28-80mm 1:3.5-5.6 II
EF 50mm 1:1.8 II
Quantaray Tech-10 cn AF 70-300mm 1:4.0-5.6 Macro
430EX
2,268 views & 0 likes for this thread
849 guests, 247 members online
