I have finally started to use the flash for my photography (or at least started to learn about using the flash). I have 2 units – Canon 580EX II and Metz 50 AF-1, plus macro ring flash Phoenix 46.
I have used 580 as a master mounted on the camera and it triggered Metz as a slave. So far so good...
The advice I need is about wireless TTL triggers. I would like to have 580 and Metz off the flash and sometimes the macro ring flash on the camera as a fill-in.
Do I need 1 transmitter with the hot shoe to mount my fill in flash and 1 receiver or do I need 2 receivers? Can 580 act as a master if mounted on the receiver? Can it trigger the other slave flash (in this case Metz 50) if 580 is mounted on the receiver? Trying to see if I can get away with one set (1 transmitter + 1 receiver)...
I am looking at Pixel King Pro Flash trigger. Has anyone got experience with it? What would be the alternative?
