Thread started 14 Jan 2014 (Tuesday) 13:04
Another Lens Specific "Starburst Effect" Question
JM ­ Photos
"Childhood ruined"
Gallery: 65 photos
Jan 14, 2014 13:04 |  #1
I have asked several different questions here inquiring the best method for achieving sharp starburst effects when shooting cities or lights at night. I have received a great amount of valuable information about the right method to achieve this effect, but am still lacking information as to what lenses perform this task the best.
I have tried countless times to achieve a sharp starburst effect with my 24-105L and it just doesn't do the trick. I have no problem getting the starburst itself, it just lacks the sharpness that I am looking for.
Here is an example of one of my better starburst shots.
IMAGE: http://farm8.staticflickr.com/7321/9313282012_d1e739fc43_c.jpg
IMAGE LINK: http://www.flickr.com …/57465123@N08/9​313282012/  (external link)
Edmonds Fisherman's Pier (external link) by jordynmurdock (external link), on Flickr
As you can see, the starburst effect looks pretty decent. The issue I have is the lack of sharpness near the tips of each point. They seem to fade and never come to a crisp point.
Here is an example of what I'm ultimately looking to achieve:
https://www.flickr.com​/photos/ryanbudhu/9231​089749/ (external link)
So my burning question seems to be whether or not there are specific lenses that accommodate this effect better than others. I would love to hear your experience and maybe see examples of sharp starburst pictures with EXIF info and what lens was used.
EDIT: I also want to add that some users talked to me a little about atmospheric conditions and how it can add moisture to the air which will lead to non-crisp starburts. I want to say that I have seen several different photos with very foggy, cloudy, and outright terrible conditions and they are still able to achieve very sharp effects. After I saw those, it confirmed that it seems to be a little more than just finding the conditions with any lens.
Canon 6D, & Sony α6000
Own: 24-105mm f/4L | Tamron 150-600mm f/5-6.3 | Rokinon 14mm f/1.8
Want: 24-70mm f/2.8 L II | 70-200mm f/2.8 L II
Website: Jordyn Murdock Photography (external link)
magoosmc
Gallery: 80 photos
Joined Jan 2012
Jan 14, 2014 13:16 |  #2
I have had very good results with a Tokina AT-X 116 PRO DX-II 11-16mm f/2.8 on a 7D. This lens can be used on a full frame at f/16 but I have not tried it on my 6D - I would expect good results.
The exif on the Queensboro Bridge shot indicates f/11 using an EF 50mm f/1.4. Have you experimented with your 50mm 1.8 to see if you get better results?
https://www.flickr.com​/photos/22055591@N05/a​lbums (external link)
JM ­ Photos
"Childhood ruined"
Gallery: 65 photos
Jan 14, 2014 13:28 |  #3
magoosmc wrote in post #16605119 (external link)
I was actually going to use the 50 because I got that suggestion last time I talked to people about the issue. Haven't had time to get around to it or found the right subject yet. I will do that before I shoot next time.
Also, how about the 17-40 for starbursts and sharpness?
MakisM1
Gallery: 50 photos
Joined Dec 2011
Jan 14, 2014 14:04 |  #4
Your photo, if I am not mistaken, is taken at f22. Diffraction has well set in by then, so there is no surprise that you complain that your starbursts are soft...
By the way, if you want comments about such a detail, upload a large resolution photo on Flickr and do not disable the copying. I can look at a photo 5184 pixels wide and decide whether is soft or not and whether the postprocessing is adequate in terms of USM.
A 1024 pixel wide shot is prqactically worthless, especially viewed with a browser.
Gerry
JM ­ Photos
"Childhood ruined"
Gallery: 65 photos
Jan 14, 2014 14:09 |  #5
MakisM1 wrote in post #16605235 (external link)
My flickr is generally just used for viewing purposes (purposefully use the small versions and save the large versions on my own computer for printing. I wouldn't like for my work to be available for anyone to take as they wish...but if you simply ask, I can just as easily upload a full res image to some quick photo sharing site like photobucket or tinyimage to temporarily share.
But thanks for the comment, Ill make sure to drop down to f/16 next time.
MakisM1
Gallery: 50 photos
Joined Dec 2011
Jan 14, 2014 14:22 |  #6
Maybe f11?
Then I will take you up on the large resolution drop, if needed...
Gerry
lance60031x
ISO composure
Joined Apr 2013
Jan 14, 2014 14:43 |  #7
I have not tried it but there is a topaz app for that -- Star Effects -- you may want to try it out.
7d mii, 5d miii, 70-200 f2.8 ii, 17-40 f4, 24-70 f2.8 ii, 24-105 f4, 100 macro L, 300 f4 canon 50 1.4, canon 85 1.8, siggy 35 f1.4 siggy 50 1.4 A
eddie3dfx
Joined Sep 2009
Jan 14, 2014 15:55 as a reply to  @ lance60031x's post |  #8
Why not just get the starbust/star filter.
Canon 6D, Canon L 24-105, Zeiss Distagon 28mm 2.8, Planar 50mm 1.4, Planar 85mm 1.4, Sonnar 135mm 2.8 & Zeiss Mutar 2x, Canon 50mm 1.8
http://www.edwinraffph​otography.com/ (external link)
gasrocks
Jan 14, 2014 16:48 |  #9
In the digital world, IMO, filters are frowned upon. The number of rays one gets from a point source of light is solely dependent on the number of aperture blades in the lens (assuning you are not shooting wide open.) An even number of blades gives that many rays ( 8 = 8.) Odd number gives double the rays (15 blades = 30 rays.) Gene
JM ­ Photos
"Childhood ruined"
Gallery: 65 photos
Jan 14, 2014 17:01 |  #10
lance60031x wrote in post #16605319 (external link)
An app? I'm not using my iPhone for photography.
eddie3dfx wrote in post #16605554 (external link)
Te starburst filters suck. I've seen so many shots where people used them and they look absolutely horrendous. Every light source picks up the starbursts with that filter...reflections, glows, everything as opposed to just light sources. Plus I'd rather do it naturally from the camera instead of relying on a filter. Plus the starburst filter makes the points way too long and they're colored weird.
lance60031x
ISO composure
Joined Apr 2013
Jan 14, 2014 18:41 |  #11
[QUOTE=JM Photos;16605728]An app? I'm not using my iPhone for photography.
lol Topaz Lab http://www.topazlabs.c​om (external link)
I do use my Mac for processing
JM ­ Photos
"Childhood ruined"
Gallery: 65 photos
Jan 14, 2014 18:51 |  #12
[QUOTE=lance60031x;166​06000]
JM Photos wrote in post #16605728 (external link)
Thank you for clarifying. I had no idea there was a software called that. When he said "app" I just thought about a phone. I don't think software or websites when someone says "app"
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Jan 14, 2014 18:57 |  #13
I just zipped through my Photostream and the sharpest "starbursts" I have were taken at f/22. As far as diffraction, it's not nearly as bad as it's claimed to be and can often be corrected for in post.
500px (external link)
1x (external link)
instagram (external link)
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Jan 14, 2014 19:03 |  #14
Ok, entirely unscientific but. . . . . . I just zipped through my photostream and what I noticed was that the longer focal lengths tended to render crisper bursts, while the shorter focal lengths rendered bursts that tended to "flare out"; getting wider as they moved from the center of the light. Now I'm feeling compelled to experiment with this.
1x (external link)
Charlie
Guess What! I'm Pregnant!
Jan 14, 2014 19:29 |  #15
Scatterbrained wrote in post #16606050 (external link)
lol, I noticed with my own photos. I prefer odd number of aperture blades than even number. Longer lenses did seem to have bigger bursts. Size of light source changes how bursts look, pointy vs wide.
Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
Panasonic GH6 - Laowa 7.5/2 - PL 15/1.7 - P 42.5/1.8 - OM 75/1.8 - PL 10-25/1.7 - P 12-32 - P 14-140
7,381 views & 0 likes for this thread, 12 members have posted to it and it is followed by 2 members.
1698 guests, 102 members online
