Hey,
Sorry if this is normal, but I just bought a T3i as a back up camera. I am used to having 5D's etc. which make no noise when you put your ear up against them, but my T3i has inside noises like fans etc.
Is this normal?
ellarose Hatchling 2 posts Joined Jan 2014 More info | Jan 16, 2014 07:56 | #1 Hey,
JohnfromPA Cream of the Crop 11,262 posts Likes: 1529 Joined May 2003 Location: Southeast Pennsylvania More info | Jan 16, 2014 08:01 | #2 ellarose wrote in post #16609990 ...my T3i has inside noises like fans etc. If you are using a lens that has image stabilization turn it off and retest. To accomplish this look on the lens barrel for a switch marked "IS". The lens has a small motor inside and you are likely hearing that as it tries to compensate for camera motion (its intended purpose). You might also do the same with the focus switch by placing it into the manual or "M" position.
Jan 16, 2014 08:06 | #3 It's making noise when you're focusing? Or just when it's switched on? If it's the latter, something is wrong. My T3i makes no noises when it is in the switched on position and not actively focusing. _______________
Jan 16, 2014 08:07 | #4 It was the image stabiliser. Thanks a lot!
| Latest registered member was a spammer, and banned as such! 1679 guests, 103 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
