It just arrived. Looking at it the lens on the flashhead looks yellowed. When I pull the diffuser out that is pure white, you can clearly see the difference. I have not gotten it home to compare to my 580EX, but I'm wondering if that could throw off the color balance somewhat or am I over-worried about this.
If it is a concern, should I try to clean it (assuming it is outer surface only, which is likely given how white the diffuser panel is) or just send it back?
Thoughts?
Just clean the lens and air it out, no sense sweating the small things.
